USB type-C (Flashing port) change to USB 3.0
1,026件の閲覧回数
Jimmychea
Hi.
I will change the i.MX8M Plus evk's USB type-C (flashing port) to USB 3.0. Any software need to change/modify, please provide steps on it? If change to USB 3.0, the UUU flashing tool still able to use ? Thanks
ラベル(3)
4 返答(返信)
1,007件の閲覧回数
joanxie
do you mean usb 3.0 port 1? this is usb 3.0 dual role port, you can use it for downloading without change SW, for HW design, pls refer to the Table 30. i.MX 8M Plus USB strapping recommendations and chapter 3.7 USB connectivity of Hardware design guide
997件の閲覧回数
Jimmychea
Yup, USB type-C (Port 1). Because i will change it to USB type-A 3.0, so may i know what is the software changes needed and will it impact the image flashing via UUU tool ? Thanks
978件の閲覧回数
joanxie
don't need change software
975件の閲覧回数
Jimmychea
For software part, require to remove the USB type-C configuration on u-boot and also the DTS file. Am i correct ?
