Is it possible to run USB in host-only mode without +5V on USB_OTGn_VBUS? Can we power internal USB block with +3.3V?
Solved! Go to Solution.
Hi J
yes, for correct operation of USB module, LDO_USB should be
powered with USB_OTGn_VBUS with value 4.4-5.5V according to
Table 10. Operating Ranges i.MX6UL Datasheet
http://cache.freescale.com/files/32bit/doc/data_sheet/IMX6ULCEC.pdf
Hi J
