USB HID Touch Screen detection with i.MX93-EVK
ソリューションへジャンプ
1,184件の閲覧回数
nicolah
My i.MX93-EVK board does not detect the USB HID touchscreen.
I am using the T080a portable touch monitor, the touchscreen is connected via USB-C.
I built used the following build commands
repo init -u https://github.com/nxp-imx/imx-manifest -b imx-linux-mickledore -m imx-6.1.55-2.2.0.xml
repo sync
MACHINE=imx93evk DISTRO=fsl-imx-fb source imx-setup-release.sh -b build
bitbake imx-image-core
The device tree is fdtfile=imx93-11x11-evk.dtb
It seems the USB HID device is not even detected.
There is not even a log in dmesg when connecting the USB cable, so the device /dev/input/touchscreen0 is not created
root@imx93evk:~# ls  /dev/input/
by-path  event0  event1
root@imx93evk:~# lsusb
root@imx93evk:~#
root@imx93evk:~# evtest
No device specified, trying to scan all of /dev/input/event*
Available devices:
/dev/input/event0:      44440000.bbnsm:pwrkey
/dev/input/event1:      WM8962 Beep Generator
Select the device event number [0-1]:
Could you provide a solution for this issue?
Nicolas
ps: the USB port is functional, a USB mouse on the same port is detected.
1,022件の閲覧回数
nicolah
Actually we found a solution.
Apparently the kernel can only see a USB host device, and so when we used a combination of a USB-C to host cable from i.MX93-EVK to a USB-C male/male cable to the HDMI screen, then we could see /dev/input/touchscreen0 mounted by the kernel.
2 返答(返信)
1,140件の閲覧回数
Zhiming_Liu
Please check your defconfig and enable all features about USB HID touch screen.
Best Regards
Zhiming
1,023件の閲覧回数
nicolah
%3CLINGO-SUB%20id%3D%22lingo-sub-1954091%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EUSB%20HID%E3%82%BF%E3%83%83%E3%83%81%E3%82%B9%E3%82%AF%E3%83%AA%E3%83%BC%E3%83%B3%E6%A4%9C%E5%87%BA(i.MX93-EVK%E3%81%AB%E3%82%88%E3%82%8B)%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1954091%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%2C%3C%2FP%3E%3CP%3Ei.MX93-EVK%E3%83%9C%E3%83%BC%E3%83%89%E3%81%8CUSB%20HID%E3%82%BF%E3%83%83%E3%83%81%E3%82%B9%E3%82%AF%E3%83%AA%E3%83%BC%E3%83%B3%E3%82%92%E6%A4%9C%E5%87%BA%E3%81%97%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%3CP%3E%E7%A7%81%E3%81%AFT080a%E3%83%9D%E3%83%BC%E3%82%BF%E3%83%96%E3%83%AB%E3%82%BF%E3%83%83%E3%83%81%E3%83%A2%E3%83%8B%E3%82%BF%E3%83%BC%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81%E3%82%BF%E3%83%83%E3%83%81%E3%82%B9%E3%82%AF%E3%83%AA%E3%83%BC%E3%83%B3%E3%81%AFUSB-C%E7%B5%8C%E7%94%B1%E3%81%A7%E6%8E%A5%E7%B6%9A%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E7%A7%81%E3%81%AF%E6%AC%A1%E3%81%AE%E3%83%93%E3%83%AB%E3%83%89%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%83%93%E3%83%AB%E3%83%89%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3C%2FP%3E%3CPRE%20class%3D%22lia-code-sample%20language-markup%22%3E%3CCODE%20translate%3D%22no%22%3Erepo%20init%20-u%20https%3A%2F%2Fgithub.com%2Fnxp-imx%2Fimx-manifest%20-b%20imx-linux-mickledore%20-m%20imx-6.1.55-2.2.0.xml%0Arepo%20sync%0A%20%0AMACHINE%3Dimx93evk%20DISTRO%3Dfsl-imx-fb%20source%20imx-setup-release.sh%20-b%20build%0A%0Abitbake%20imx-image-core%3C%2FCODE%3E%3C%2FPRE%3E%3CP%3E%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%83%84%E3%83%AA%E3%83%BC%E3%81%AF%20fdtfile%3Dimx93-11x11-evk.dtb%20%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3CP%3EUSB%20HID%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%82%82%E6%A4%9C%E5%87%BA%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%AA%E3%81%84%E3%82%88%E3%81%86%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3EUSB%E3%82%B1%E3%83%BC%E3%83%96%E3%83%AB%E3%82%92%E6%8E%A5%E7%B6%9A%E3%81%97%E3%81%A6%E3%82%82dmesg%E3%81%AB%E3%83%AD%E3%82%B0%E3%82%A4%E3%83%B3%E3%81%99%E3%82%89%E3%81%97%E3%81%AA%E3%81%84%E3%81%9F%E3%82%81%E3%80%81%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%2Fdev%2Finput%2Ftouchscreen0%E3%81%AF%E4%BD%9C%E6%88%90%E3%81%95%E3%82%8C%E3%81%BE%E3%81%9B%E3%82%93%3C%2FP%3E%3CPRE%20class%3D%22lia-code-sample%20language-markup%22%3E%3CCODE%20translate%3D%22no%22%3Eroot%40imx93evk%3A~%23%20ls%20%20%2Fdev%2Finput%2F%0Aby-path%20%20event0%20%20event1%0Aroot%40imx93evk%3A~%23%20lsusb%0Aroot%40imx93evk%3A~%23%0Aroot%40imx93evk%3A~%23%20evtest%0ANo%20device%20specified%2C%20trying%20to%20scan%20all%20of%20%2Fdev%2Finput%2Fevent*%0AAvailable%20devices%3A%0A%2Fdev%2Finput%2Fevent0%3A%20%20%20%20%20%2044440000.bbnsm%3Apwrkey%0A%2Fdev%2Finput%2Fevent1%3A%20%20%20%20%20%20WM8962%20Beep%20Generator%0ASelect%20the%20device%20event%20number%20%5B0-1%5D%3A%20%3C%2FCODE%3E%3C%2FPRE%3E%3CP%3E%E3%81%93%E3%81%AE%E5%95%8F%E9%A1%8C%E3%81%AE%E8%A7%A3%E6%B1%BA%E6%96%B9%E6%B3%95%E3%82%92%E6%95%99%E3%81%88%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3ENicolas%3C%2FP%3E%3CP%3Eps%3AUSB%E3%83%9D%E3%83%BC%E3%83%88%E3%81%AF%E6%A9%9F%E8%83%BD%E3%81%97%E3%81%A6%E3%81%8A%E3%82%8A%E3%80%81%E5%90%8C%E3%81%98%E3%83%9D%E3%83%BC%E3%83%88%E4%B8%8A%E3%81%AEUSB%E3%83%9E%E3%82%A6%E3%82%B9%E3%81%8C%E6%A4%9C%E5%87%BA%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1990135%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%97%A5%E6%99%82%3Ai.MX93-EVK%E3%81%AB%E3%82%88%E3%82%8BUSB%20HID%E3%82%BF%E3%83%83%E3%83%81%E3%82%B9%E3%82%AF%E3%83%AA%E3%83%BC%E3%83%B3%E6%A4%9C%E5%87%BA%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1990135%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E5%AE%9F%E3%81%AF%E3%80%81%E7%A7%81%E3%81%9F%E3%81%A1%E3%81%AF%E8%A7%A3%E6%B1%BA%E7%AD%96%E3%82%92%E8%A6%8B%E3%81%A4%E3%81%91%E3%81%9F%E3%81%AE%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%A9%E3%81%86%E3%82%84%E3%82%89%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%81%AFUSB%E3%83%9B%E3%82%B9%E3%83%88%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%81%97%E3%81%8B%E8%A6%8B%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E3%81%A7%E3%81%8D%E3%81%AA%E3%81%84%E3%81%AE%E3%81%A7%E3%80%81i.MX93-EVK%E3%81%8B%E3%82%89%E3%81%AEUSB-C%E3%83%9B%E3%82%B9%E3%83%88%E3%82%B1%E3%83%BC%E3%83%96%E3%83%AB%E3%81%A8HDMID%E3%82%B9%E3%82%AF%E3%83%AA%E3%83%BC%E3%83%B3%E3%81%B8%E3%81%AEUSB-C%E3%82%AA%E3%82%B9%E3%82%B1%E3%83%BC%E3%83%96%E3%83%AB%E3%81%AE%E7%B5%84%E3%81%BF%E5%90%88%E3%82%8F%E3%81%9B%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%9F%E3%81%A8%E3%81%8D%E3%80%81%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%81%AB%E3%82%88%E3%81%A3%E3%81%A6%E3%83%9E%E3%82%A6%E3%83%B3%E3%83%88%E3%81%95%E3%82%8C%E3%81%9F%2Fdev%2Finput%2Ftouchscreen0%E3%82%92%E8%A6%8B%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1956142%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%97%A5%E6%99%82%3Ai.MX93-EVK%E3%81%AB%E3%82%88%E3%82%8BUSB%20HID%E3%82%BF%E3%83%83%E3%83%81%E3%82%B9%E3%82%AF%E3%83%AA%E3%83%BC%E3%83%B3%E6%A4%9C%E5%87%BA%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1956142%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%20%3C%2FP%3E%0A%3CP%3Edefconfig%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%80%81USBHID%E3%82%BF%E3%83%83%E3%83%81%E3%82%B9%E3%82%AF%E3%83%AA%E3%83%BC%E3%83%B3%E3%81%AB%E9%96%A2%E3%81%99%E3%82%8B%E3%81%99%E3%81%B9%E3%81%A6%E3%81%AE%E6%A9%9F%E8%83%BD%E3%82%92%E6%9C%89%E5%8A%B9%E3%81%AB%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%3CBR%20%2F%3E%E5%BF%97%E6%98%8E%3C%2FP%3E%3C%2FLINGO-BODY%3E
