UART2 not working with latest freescale linux BSP (10.07.11)
2,120 次查看
ma_giorgio
I downloaded form Freescale web site the L2.6.31_10.07.11_ER_source_bundle.
With the BSP and with ltib included in this bundle, I built a zImge for My EVM babbage board.
Now, I am not able to get UART2 and UART3 working .
With the previous version of the BSP provided by Freescale, with a simple pin settings in mx51_babbage_gpio.c file, all UARTs were working on my board.
Now, with the latest L2.6.31_10.07.11_ER_source_bundle I am no longer able to take the UART2 and UAR3 working.
Can anyone give me a suggestions?
Giorgio.
标签 (1)
标记 (2)
6 回复数
1,919 次查看
Yogesh1z
Hi Alex,
Could you please let us know the issue with UART2. Look at our config. i.mx515 pins EIM_D17 & EIM_D18 in
ALT3 Mode (RX/TX of UART2 instance) and EIM_D25 & EIM_D26 in ALT4 mode (CTS/RTS of UART2 Instance) for Bluetooth HCI host interface.
Please advise us asap. We have stuck since long time.
Alex Otero said:
Got UART 2 working on L2.6.31_10.07.11_ER_source_bundle.
1,919 次查看
mbp
Contributor V
Yogesh - did you get this working?
1,919 次查看
mbp
Contributor V
Yes - How did you fix this?   I'm running into similar issues trying to get UART2 (and then 3) on r9.2.  Especially since mx51_babbage_gpio.c and it's associated header file are not longer in the mach-mx5 folder!
1,919 次查看
satank
Can you post what you did to get this working?
1,919 次查看
aotero
1,919 次查看
aotero
Have you been able to get around this? I'm working on the same issue if I have any success I will let you know. I've made some changes to serial.h, board-mx51_babbage.h I'm looking at the IOMUXCC tool and checking that right now to make sure I have the pins set correctly. In my situation I'm able to run the mxc_uart_test.out /dev/ttymxc1 I'm able to read the TEST data while I have a serial sniffer on /dev/ttymxc1 and I'm also able to stream a bunch of data to /dev/ttymxc1 I'm not able to view anything happening when we hook a scope to the ALT0 -> C14 pin. Alex
