U-boot flashing using JTAG on 8MNANOLPD4-EVK
2,997件の閲覧回数
Sal2020
I am working on (8MNANOLPD4-EVK) based custom board.
Trying to boot imx8 nano with u-boot & kernel-Setting from Norflash and root filesystem in eMMC.
How to I flash u-boot using JTAG interface? And
For that, which JTAG emulator I can use?
If there are any steps or guide available to do the same is really helpful.
タグ(4)
2,780件の閲覧回数
Sal2020
Hi b45499
we have decided for other solution
Thank you for your support
タグ(1)
5 返答(返信)
2,972件の閲覧回数
Sal2020
2,957件の閲覧回数
Rita_Wang
Do not use the JTAG to download, we support the usb download mode. You can use the uuu tool we supply.
2,953件の閲覧回数
Sal2020
Thank you for the feedback
"Do not use the JTAG to downloadWhy?
But this method is not productive for end of line products.
we will soon produce big quantity with (MIMX8MN6DVTJZAA) and we need JTAG for first flashing of bootloader on pcb customer (in END of line).
in my pcb customer I need the USB interface for other purposes (for example modem, GPS, keyboard ..etc).
best regards
2,908件の閲覧回数
Rita_Wang
We do not supply the tool for the JTAG download and the download speed is low, images are large. So we not not have this design and do not recommend customer to use this design. Here recommend you to use a multiplexer/demultiplexer USB 2.0 Switch. I draw the solution and email to you.
2,781件の閲覧回数
Sal2020
Hi b45499
タグ(1)
