U-Boot Build issue
U-Boot Build issue
1,006 次查看
devikar
We have setup Yocto project 4.9.11_1.0.0 on a imx6qpsabresd based custom board.
We  want to build u-boot image.
We have tried to build u-boot using following command
   $ MACHINE=imx6qpsabresd bitbake -c deploy u-boot-imx
But the output images were not getting updated.
Hence we have cleaned u-boot using the command "bitbake -c clean u-boot-imx "
It has cleaned the output images but failing to build again.
We are not getting any error if we execute " MACHINE=imx6qpsabresd bitbake -c deploy u-boot-imx" but we are not able to see any output images of u-boot in tmp/deplot/images/imx6qpsabresd/ directory.
Please let us know how to restore the u-boot images again.
Devika
标签 (2)
891 次查看
kunalkotecha1
Senior Contributor II
Hi devikar@implantaire.com,
Once you have done the setup environment for the machine that you are using, you do not need to use MACHINE during image building every time.
Please use the below command to set up the environment for the first time:
DISTRO=<distro name> MACHINE=<machine name> source fsl-setup-release.sh -b <build dir>
Please use the following steps to clean and build u-boot:
bitbake -c cleansstate u-boot-imx
bitbake -f u-boot-imx
Please find attached Yocto Project User Guide for your reference. Let us know in case of any other concerns.
Kunal
891 次查看
Bio_TICFSL
Good
