Trying to develop linux application to perfom inference on ethosu65
1,823 次查看
phanichinimilli
On imx93, my Goal is to comeup with an application that can run a vela model on ethosu65. I am able to build a linux image with ML examples and run the same(label_image) on A55 and on ethosu65.
im interested in finding source code for label_image application but not able to find any source code in yocto build directory
标签 (2)
1,783 次查看
phanichinimilli
Thanks for the prompt response.
 github points to the python code, I'm more interested in finding c/c++ source code that invokes ethos driver.
so that I can experiment, modify and recompile and copy it to rootfs
I'm following build procedure mentioned in
1,806 次查看
Chavira
Hi @phanichinimilli!
Thank you for contacting NXP Support!
The examples can be found in our github.
Best Regards!
Chavira
1,734 次查看
phanichinimilli
Is there a way I can find c++ code for the label_image application, I think it is modified version of tensorflow's label_image i.e. https://github.com/tensorflow/tensorflow/blob/master/tensorflow/lite/examples/label_image/label_imag...
