Trying to add fw_setenv/fw_printenv to image rootfs.
已解决
跳至解决方案
1,321 次查看
meetalipatel
Hi Team,
I am trying to integrate meta-swupdate to Yocto Linux BSP Linux 6.1.22_2.0.0​ for a custom board based on i.MX6ULL processor. I followed this document for porting. I am using the meta-swupdate layer from here
After, building the image I cannot see the fw_setenv and fw_printenv commands in the rootfs. I have added "libubootenv" to the IMAGE_INSTALL variable.
Am I missing anything here?
Thanks & Regards
Meetali Patel
1 解答
1,280 次查看
meetalipatel
I got the solution. We need to add "libubootenv-bin" to IMAGE_INSTALL variable.
Meetali Patel
在原帖中查看解决方案
1 回复
1,281 次查看
meetalipatel
Meetali Patel
