Troubleshooting 8ULP EVK Boot Fuses
已解决
跳至解决方案
1,468 次查看
KipW
I am testing recovery methods using the MCIMX8ULP-BB EVK.  I successfully burned BT_FUSE_SEL and BT0_CFG1 (Boot from A35/eMMC and M33/QSPI) using u-boot's fuse command. When I set my boot pins to "00" I get the serial bootloader. However, since I have working images in A35's eMMC and M33's NOR, I should be seeing the the kernel boot and the output from M33's image.
Ideas on how to troubleshoot this?  Does booting from the fuses *require* that I use signed/secure images?
标签 (1)
1 解答
1,361 次查看
KipW
Turns out that the 'fuse' command in u-boot requires a little-endian value for burning. The u-boot command does not perform the endian swap for you
在原帖中查看解决方案
3 回复数
1,362 次查看
KipW
1,419 次查看
Chavira
HI @KipW,
For that usage you should flash the images following the next instructions:
To burn dual-boot image and rootfs to eMMC and FlexSPI0 NOR flash, perform the following steps:
1. Prepare imx-boot-imx8ulpevk-sd.bin-flash_singleboot_m33, imx-boot-imx8ulpevk-
sd.bin-flash_dualboot, imx-boot-imx8ulpevk-sd.bin-flash_dualboot_m33, and
<rootfs.wic>.
2. Update the UUU script file uuu_8ulp_dual.auto with the file path and name of the images above.
3. Run uuu mfgtools/scripts/samples/uuu_8ulp_dual.auto.
For detailed usage of UUU, see github.com/NXPmicro/mfgtools/wiki.
1,388 次查看
KipW
I pulled down LF_v6.12.34-2.1.0_images_IMX8ULPEVK, updated the samples/uuu_8ulp_dual.auto to point to the local bin files, burned the images and same result.
When I POR, with Boot Switch set to xxxx_xx00, I see nothing and the SDPS device appears.  I do not have any SRK or certs or any of the CST set up.
%3CLINGO-SUB%20id%3D%22lingo-sub-2193739%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%AF%B9%208ULP%20EVK%20%E5%90%AF%E5%8A%A8%E7%86%94%E4%B8%9D%E8%BF%9B%E8%A1%8C%E6%95%85%E9%9A%9C%E6%8E%92%E9%99%A4%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2193739%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%88%91%E6%AD%A3%E5%9C%A8%E4%BD%BF%E7%94%A8%20MCIMX8ULP-BB%20EVK%20%E6%B5%8B%E8%AF%95%E6%81%A2%E5%A4%8D%E6%96%B9%E6%B3%95%E3%80%82%20%E6%88%91%E4%BD%BF%E7%94%A8%20u-boot%20%E7%9A%84%20%3CSPAN%3E%E7%86%94%E4%B8%9D%20%E5%91%BD%E4%BB%A4%E6%88%90%E5%8A%9F%E7%83%A7%E5%BD%95%E4%BA%86%20BT_FUSE_SEL%20%E5%92%8C%20BT0_CFG1%EF%BC%88%E4%BB%8E%20A35%2FeMMC%20%E5%92%8C%20M33%2FQSPI%20%E5%90%AF%E5%8A%A8%EF%BC%89%E3%80%82%E5%BD%93%E6%88%91%E5%B0%86%E5%90%AF%E5%8A%A8%E5%BC%95%E8%84%9A%E8%AE%BE%E7%BD%AE%E4%B8%BA%20%22%2000%20%22%20%E6%97%B6%EF%BC%8C%E6%88%91%E5%BE%97%E5%88%B0%E4%BA%86%E4%B8%B2%E8%A1%8C%E5%BC%95%E5%AF%BC%E5%8A%A0%E8%BD%BD%E7%A8%8B%E5%BA%8F%E3%80%82%E4%BD%86%E6%98%AF%EF%BC%8C%E7%94%B1%E4%BA%8E%E6%88%91%E5%9C%A8%20A35%20%E7%9A%84%20eMMC%20%E5%92%8C%20M33%20%E7%9A%84%E6%88%96%E9%9D%9E%20%E4%B8%AD%E6%9C%89%E5%B7%A5%E4%BD%9C%E6%98%A0%E5%83%8F%EF%BC%8C%E6%88%91%E5%BA%94%E8%AF%A5%E7%9C%8B%E5%88%B0%E5%86%85%E6%A0%B8%E5%90%AF%E5%8A%A8%E5%92%8C%20M33%20%E6%98%A0%E5%83%8F%E7%9A%84%E8%BE%93%E5%87%BA%3C%2FSPAN%3E%E3%80%82%3C%2FP%3E%3CP%3E%E5%A6%82%E4%BD%95%E6%8E%92%E9%99%A4%E6%95%85%E9%9A%9C%EF%BC%9F%20%E4%BB%8E%E7%86%94%E4%B8%9D%E5%90%AF%E5%8A%A8%E6%98%AF%E5%90%A6%E9%9C%80%E8%A6%81*%E6%88%91%E4%BD%BF%E7%94%A8%E7%AD%BE%E5%90%8D%2F%E5%AE%89%E5%85%A8%E6%98%A0%E5%83%8F%EF%BC%9F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-2193739%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3Ei.MX8ULP%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2195990%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Troubleshooting%208ULP%20EVK%20Boot%20Fuses%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2195990%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E4%BA%8B%E5%AE%9E%E8%AF%81%E6%98%8E%EF%BC%8Cu-boot%20%E4%B8%AD%E7%9A%84%20%E2%80%9C%E7%86%94%E4%B8%9D%E2%80%9D%20%E5%91%BD%E4%BB%A4%E9%9C%80%E8%A6%81%E4%B8%80%E4%B8%AA%E5%B0%8F%E7%AB%AF%E5%80%BC%E6%89%8D%E8%83%BD%E7%83%A7%E5%BD%95%E3%80%82u-%E5%90%AF%E5%8A%A8%20%E5%91%BD%E4%BB%A4%E6%97%A0%E6%B3%95%E4%B8%BA%E4%BD%A0%E6%89%A7%E8%A1%8C%E5%AD%97%E8%8A%82%E5%BA%8F%E4%BA%A4%E6%8D%A2%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2195203%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Troubleshooting%208ULP%20EVK%20Boot%20Fuses%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2195203%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%88%91%E4%B8%8B%E8%BD%BD%E4%BA%86%20LF_v6.12.34-2.1.0_images_IMX8ULPEVK%E3%80%81%E6%9B%B4%E6%96%B0%E4%BA%86%20samples%2Fuuu_8ulp_dual.auto%EF%BC%8C%E4%BD%BF%E5%85%B6%E6%8C%87%E5%90%91%E6%9C%AC%E5%9C%B0%20bin%20%E6%96%87%E4%BB%B6%EF%BC%8C%E7%84%B6%E5%90%8E%E5%88%BB%E5%BD%95%E4%BA%86%E9%95%9C%E5%83%8F%EF%BC%8C%E7%BB%93%E6%9E%9C%E7%9B%B8%E5%90%8C%E3%80%82%3C%2FP%3E%3CP%3E%E5%BD%93%E6%88%91%20POR%20%E6%97%B6%EF%BC%8C%E5%B0%86%E5%90%AF%E5%8A%A8%20Switch%20%E8%AE%BE%E7%BD%AE%E4%B8%BA%20xxxx_xx00%EF%BC%8C%E6%88%91%E4%BB%80%E4%B9%88%E4%B9%9F%E7%9C%8B%E4%B8%8D%E8%A7%81%EF%BC%8CSDPS%20%E8%AE%BE%E5%A4%87%E5%B0%B1%E4%BC%9A%E5%87%BA%E7%8E%B0%E3%80%82%E6%88%91%E6%B2%A1%E6%9C%89%E4%BB%BB%E4%BD%95%20SRK%20%E6%88%96%E8%AF%81%E4%B9%A6%E6%88%96%E4%BB%BB%E4%BD%95%20CST%20%E5%AE%89%E8%A3%85%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2194453%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Troubleshooting%208ULP%20EVK%20Boot%20Fuses%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2194453%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F256209%22%20target%3D%22_blank%22%3E%40KipW%3C%2FA%3E%E3%80%81%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E4%B8%BA%E6%AD%A4%EF%BC%8C%E6%82%A8%E5%BA%94%E6%8C%89%E7%85%A7%E4%BB%A5%E4%B8%8B%E8%AF%B4%E6%98%8E%E5%88%B7%E6%96%B0%E6%98%A0%E5%83%8F%EF%BC%9A%3CBR%20%2F%3E%3CBR%20%2F%3E%E8%A6%81%E5%B0%86%E5%8F%8C%E5%90%AF%E5%8A%A8%E6%98%A0%E5%83%8F%E5%92%8C%20rootfs%20%E5%88%BB%E5%BD%95%E5%88%B0%20eMMC%20%E5%92%8C%20FlexSpi0%20%E6%88%96%E9%9D%9E%E9%97%AA%E5%AD%98%EF%BC%8C%E8%AF%B7%E6%89%A7%E8%A1%8C%E4%BB%A5%E4%B8%8B%E6%AD%A5%E9%AA%A4%EF%BC%9A%3C%2FP%3E%0A%3CP%3E%3CBR%20%2F%3E1%E3%80%82%E5%87%86%E5%A4%87%20imx-%E5%90%AF%E5%8A%A8-imx8ulpevk-sd.bin-flash_single%E5%90%AF%E5%8A%A8_m33%E3%80%81imx-%E5%90%AF%E5%8A%A8-imx8ulpevk-sd.bin-flash_dual%E5%90%AF%E5%8A%A8%E3%80%81imx-%E5%90%AF%E5%8A%A8-imx8ulpevk-sd.bin-flash_dual%E5%90%AF%E5%8A%A8_dual%E5%90%AF%E5%8A%A8_m33%3CBR%20%2F%3E%20%E5%92%8C%3CBR%20%2F%3E%3CROOTFS.WIC%3E%20%E3%80%82%3C%2FROOTFS.WIC%3E%3C%2FP%3E%0A%3CP%3E%3CBR%20%2F%3E2.%E7%94%A8%E4%B8%8A%E8%BF%B0%E5%9B%BE%E5%83%8F%E7%9A%84%E6%96%87%E4%BB%B6%E8%B7%AF%E5%BE%84%E5%92%8C%E5%90%8D%E7%A7%B0%E6%9B%B4%E6%96%B0%20UUU%20%E8%84%9A%E6%9C%AC%E6%96%87%E4%BB%B6%20uuu_8ulp_dual.auto%E3%80%82%3C%2FP%3E%0A%3CP%3E%3CBR%20%2F%3E3.%E8%BF%90%E8%A1%8C%20uuu%20mfgtools%2Fscripts%2Fsamples%2Fuuu_8ulp_dual.auto%E3%80%82%3CBR%20%2F%3E%E6%9C%89%E5%85%B3%20UUU%20%E7%9A%84%E8%AF%A6%E7%BB%86%E7%94%A8%E6%B3%95%EF%BC%8C%E8%AF%B7%E5%8F%82%E8%A7%81%20github.com%2FNXPmicro%2Fmfgtools%2Fwiki%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E
