Trouble building Android Marshmallow for i.MX7D SABRESD board
billtonn
I'm trying to build Android Marshmallow for the board using the instructions in the Android User's Guide (document number AUG, revision M6.0.1_2.1.0, 07/2016). It's failing during the build of u-boot saying it has no rule to make mx7dsabresdandroid_config.
If I look in ~/myandroid/bootable/bootloader/uboot-imx/board/freescale, there is no folder for the mx7sabresd, which I suspect might be why it's failing.
Labels (2)
gusarambula
Hello Bill Tonnies,
If the problem is related to u-boot in specific I would say there probably was an error when cloning the repository. I tested the steps on section 3.1 of the Android User’s Guide and there is a mx7dsabresd folder.
I would recommend repeating this steps to make sure the cloning is correct.
$ cd ~/myandroid/bootable
$ mkdir bootloader
$ cd bootloader
$ git clone git://git.freescale.com/imx/uboot-imx.git uboot-imx
$ cd uboot-imx
$ git checkout m6.0.1_2.1.0-ga
Let us know if this helps!
gusarambula
Hello Bill Tonnies,
$ mkdir bootloader
$ cd bootloader
$ cd uboot-imx
billtonn
It turns out that what it was. I guess I missed the "git checkout m6.0.1_2.1.0-ga" step. :-/
Thanks for your help!
