Trace connection on i.MX 9
Anurag_Singh
This is my first time using trace connection and i am not sure what pins on i.MX 9 can be used for trace_clk and trace data along with standard JTAG connections. Request you to provide any reference document or deign which can help me to undertsand interfacing of Trace connections.
JosephAtNXP
You can use CoreSight Serial Wire Output.
Which are the same pins for JTAG connection.
Anurag_Singh
Thanks for the reply.
Does that mean that following schematic should work
Anurag
JosephAtNXP
Yes, it is correct,
