Touchpannel calibration with SPI based ADS7846 touch controller in Wandboard Quad!
1,545件の閲覧回数
mandarkhire
This is my first discussion in this community forum.
I am using Wandboard-Quad Revision C1.
OS:- Android 4.4.2
Kernel version:- 3.0.35
I am trying to use LCD which made by KYOCERA Industrial Ceramics Corporation - Display Division.
Product code is 'T-55343GD035JU-LW-AEN'
http://www.kyocera-display.com/products/partdetail.asp?PartNumber=T-55343GD035JU-LW-AEN
I found datasheet by following Link:-
http://www.kyocera-display.com/SiteImages/PartList/SPEC/T-55343GD035JU-LW-AEN%20final.pdf
For touch panel i use ADS7846 TOUCH SCREEN CONTROLLER which found at http://www.ti.com/product/ads7846,
By technical documentation http://www.ti.com/general/docs/lit/getliterature.tsp?genericPartNumber=ads7846&fileType=pdf
Its 16,14,12,15 no.pins i connect to Wandboard's Carrier boards JP4 11,7,9,13 respectively by using one custom extension PCB which used between Wandboard & LCD.
All other details in following link where i asked question in Wandboard forum:-
Wandboard Discussion Forums • View topic - How to use ADS7846 Driver for Touch panel?
In this forum i want to ask,
I detect getevent, i can see .idc file in Android, i can see 'interrupt count increases for ADS7846'.
Now what should i do so when i touch, display also respond as our Android mobile respond when we touch?
Need Help.
1,108件の閲覧回数
mandarkhire
Hi all,
Please someone try to help me to solve this!:smileyconfused:
