The wave of PWM output
1,895件の閲覧回数
lpheni
Greetings,
I use gpio1_11 as PWM2 output.
After I set the PWM output, if the frequency is set to 8KHZ, period = 125000, duty_cycle = 62000, then the output is a square wave. If set to 8MHZ then the output is sine wave,period = 125, duty_cycle = 62.
Can you help me find out what the reason is? Thank you!
3 返答(返信)
1,820件の閲覧回数
lpheni
Hello, this problem is caused by the oscilloscope. After replacing the oscilloscope, the output is square wave.
Thanks!
1,854件の閲覧回数
Zhiming_Liu
Please refer https://bbs.21ic.com/icview-3304758-1-1.html
Best Regards
Zhiming
1,886件の閲覧回数
lpheni
