The status of FET in PMIC_ON_REQ pin
926 次查看
ko-hey
Senior Contributor II
Hi all,
I have a question about the status of FET in PMIC_ON_REQ.
The FET of PMIC_ON_REQ will be open drain when the voltage of VDD_SNVS_IN is input.
Am I correct ?
The FET stay GND before the voltage of VDD_SNVS_IN is input.
Am I correct ?
Ko-hey
标签 (4)
788 次查看
igorpadykov
Hi Ko-hey
>The FET of PMIC_ON_REQ will be open drain when the voltage of VDD_SNVS_IN is input. Am I correct ?
 correct
>The FET stay GND before the voltage of VDD_SNVS_IN is input. Am I correct ?
yes correct.
789 次查看
igorpadykov
Hi Ko-hey
 correct
yes correct.
