The ext4 file is broken in AndroidKK4.4.3 on MX6Q-SABRE-SD
1,814件の閲覧回数
yuuki
Senior Contributor II
Dear all,
We run Android4 .4.3 on MX6Q-SABRE-SD board.
Android is booted from eMMC.
We turn off an AC power directly without using Shutdown of Android.
In this case EXT4 file is sometimes broken.
We found the description of the following URL.
http://www.phoronix.com/scan.php?page=news_item&px=Linux-4-EXT4-RAID-Issue-Found
http://www.phoronix.com/scan.php?page=news_item&px=MTIxNDQ
https://linux.slashdot.org/story/12/10/24/1848203/ext4-data-corruption-bug-hits-linux-kernel
Are these Bug measures included in AndroidKK4 .4.3 BSP?
Yuuki
ラベル(2)
タグ(2)
3 返答(返信)
1,465件の閲覧回数
joanxie
I found we reported ext4 issue as below:
"Kernel will panic with below log after factory reset:
EXT4-fs error (device mmcblk1p4): ext4_validate_block_bitmap:380: comm init: bg 17: block 557056: invalid block bitmap Aborting journal on device mmcblk1p4-8.
Kernel panic - not syncing: EXT4-fs (device mmcblk1p4): panic forced after error Rebooting in 5 seconds..
The root cause is the data type conversion issue.
When a 32-bit data mutiply a 32-bit data, it will still get a 32-bit data.
The 64-bit offset will be cut to 32 bit"
this issue is fixed in the latest android version.
1,465件の閲覧回数
yuuki
joanxie
Dear Joan Xie-san,
I'm sorry to press you about this, how about the situation afterward?
Your kind helps would be greatly appreciated.
Yuuki
1,465件の閲覧回数
yuuki
joanxie
Dear Joan Xie-san,
Thank you for your response.
Does this mean Android M6?
Or is it Andorid N7?
Would you tell me the modified point for this issue?
We want to backport it in AndroidKK4.4.3.
Yuuki
