Hi all,
I don't know how to fix the problem that when the Qt app is launched on the board, the content on the screen will scroll up to the edge before displaying the current Qt app interface.
The chip I used is IMX6SX, the BSP version is imx-yocto-L4.14.98_2.0.0_ga.The lcd use elcdif.The file system is compiled in Yocto by using the command:
bitbake fsl-image-qt5-validation-imx
The video and log of the test are attached.
Tks
Solved! Go to Solution.
TKS! I have solved the problem of masking mxsfb_set_par in the mxsfb.c
I think this is a QT issue. You may ask this in the QT forum.
https://www.qter.org/ (Chinese)
