The HDMI display of IMX6Q
922 次查看
红彦陈
Our company is mainly to do rail transportation related products. We are in the development of a card reader,.The number of usage will be up to 30000.In the development board, we use the IMX6Q series chip of your company.In the process of research and development At present, we have a problem,that HDMI does not display.,so We hope that your company can provide technical support.
842 次查看
sinanakman
Senior Contributor III
This is a community forum so if you state your problem
clearly someone will try to help you. This can be a Freescale
employee or someone else who had experience with the
issue. If you need direct support from Freescale you are
probably better off creating a Service Request at Freescale
web site. Otherwise, just describe your HDMI problem clearly
and see if someone can help you here.
Hope this helps.
Sinan Akman
