The Frame skip problem on WebView of AndroidKK4.4.3 for i.MX6Q_SABRE_SDB
1,887 次查看
yuuki
Senior Contributor II
Dear all,
Our customer runs AndroidKK4.4.3 on i.MX6Q_SABRE_SDB
They use attached HTML.
However, frame skips occur frequently, and the following log is displayed.
"Skipped 37 frames!  The application may be doing too much work on its main thread."
This problem does not occur if AndroidKK4.4.2 is used.
Would you teach the probable cause?
Would you teach the point that you should investigate?
yuuki
Original Attachment has been moved to: codepenio.zip
标签 (1)
标记 (3)
4 回复数
1,627 次查看
yuuki
Dear all,
Can this problem be reproduced?
Could someone advise on this problem?
Yuuki
1,627 次查看
SergioSolis
Hello Yuuki, our team of experts is looking into the problem, I will be updating you as soon as I have a response from them
best regards,
Sergio
1,627 次查看
yuuki
Dear Sergio-san,
Thank you for your reply.
We are looking forward to receiving your swift response.
Yuuki
1,627 次查看
yuuki
Dear Sergio-san,
Thank you for your support.
We got additional information.
However, we made the following SR because a confidential information might be included.
SR#: 1-3742814821
Please confirm this.
Yuuki
