Testing a single GPIO input on FRDM i.MX93 with gpioget
44 次查看
ericpronovost
I’m trying to test a single GPIO input on the FRDM i.MX93 board. I want to start simple using gpioget.
Here’s what I have so far:
I ran:
sudo gpioinfo
gpiochip0 - 32 lines:
        line   0:      unnamed       unused   input  active-high
        line   1:      unnamed       unused   input  active-high
        line   2:      unnamed       unused   input  active-high
        line   3:      unnamed       unused   input  active-high
        line   4:      unnamed       unused   input  active-high
        line   5:      unnamed       unused   input  active-high
        line   6:      unnamed       unused   input  active-high
        line   7:      unnamed       unused   input  active-high
        line   8:      unnamed   "spi0 CS0"  output   active-low [used]
        line   9:      unnamed       unused   input  active-high
        line  10:      unnamed       unused   input  active-high
        line  11:      unnamed       unused   input  active-high
        line  12:      unnamed       unused   input  active-high
        line  13:      unnamed       unused   input  active-high
        line  14:      unnamed       unused   input  active-high
        line  15:      unnamed       unused   input  active-high
        line  16:      unnamed       unused   input  active-high
        line  17:      unnamed       unused   input  active-high
        line  18:      unnamed       unused   input  active-high
        line  19:      unnamed       unused   input  active-high
        line  20:      unnamed       unused   input  active-high
        line  21:      unnamed       unused   input  active-high
        line  22:      unnamed       unused   input  active-high
        line  23:      unnamed       unused   input  active-high
        line  24:      unnamed       unused   input  active-high
        line  25:      unnamed       unused   input  active-high
        line  26:      unnamed       unused   input  active-high
        line  27:      unnamed       unused   input  active-high
        line  28:      unnamed       unused   input  active-high
        line  29:      unnamed       unused   input  active-high
        line  30:      unnamed       unused   input  active-high
        line  31:      unnamed       unused   input  active-high
gpiochip1 - 32 lines:
        line   0:      unnamed         "cd"   input   active-low [used]
        line   6:      unnamed       unused  output  active-high
        line   7:      unnamed "regulator-usdhc2" output active-high [used]
        line   8:      unnamed       unused   input  active-high
        line  27:      unnamed  "interrupt"   input  active-high [used]
gpiochip2 - 32 lines:
gpiochip3 - 32 lines:
gpiochip4 - 24 lines:
        line   1:      unnamed  "interrupt"   input  active-high [used]
        line   5:      unnamed "User Button1" input active-high [used pull-up]
        line   6:      unnamed "User Button2" input active-high [used pull-up]
        line  11:      unnamed  "interrupt"   input  active-high [used]
        line  12:      unnamed      "reset"  output   active-low [used]
        line  13:      unnamed "pinctrl-assert" output active-high [used]
        line  14:      unnamed "regulator-vdd-12v" output active-high [used]
        line  15:      unnamed  "PHY reset"  output   active-low [used]
        line  16:      unnamed  "PHY reset"  output   active-low [used]
        line  19:      unnamed "pinctrl-assert" output active-high [used]
        line  20:      unnamed "regulator-usdhc3" output active-high [used]
        line  21:      unnamed      "reset"  output   active-low [used]
        line  23:      unnamed "regulator-can2-stby" output active-low [used]
gpiochip5 - 8 lines:
        line   0:      unnamed "pinctrl-assert" output active-high [used]
0 回复数
