Tensorflow Savedmodel to tflite conversion which supports imx8mp NPU
799件の閲覧回数
subbareddyai
I would like to convert the Tensorflow Savedmodel to tflite model which supports imx8mp NPU.
I followed the below steps with no success
python models/research/object_detection/exporter_main_v2.py \
--input_type image_tensor \
--pipeline_config_path training_dir/pipeline.config \
--trained_checkpoint_dir training_dir/checkpoint \
--output_directory exported-model
and I make sure its fixed shape model {
ssd {
image_resizer {
fixed_shape_resizer {
height: 320
width: 320
and also Ensure TFLite-Compatible Ops
ssd {
feature_extractor {
type: "ssd_mobilenet_v2_fpn_keras"
use_depthwise: true
box_predictor {
convolutional_box_predictor {
use_depthwise: true
tflite conversion script
import tensorflow as tf
import pathlib
saved_model_dir = "exported-model/saved_model"
converter = tf.lite.TFLiteConverter.from_saved_model(saved_model_dir)
converter.optimizations = [tf.lite.Optimize.DEFAULT]
# Provide representative dataset for INT8 calibration
def representative_data_gen():
data_dir = pathlib.Path("dataset/val")
for img_path in data_dir.glob("*.jpg"):
img = tf.keras.preprocessing.image.load_img(img_path, target_size=(320, 320))
img = tf.keras.preprocessing.image.img_to_array(img)
img = img[tf.newaxis, ...] / 255.0
yield [img.astype("float32")]
converter.representative_dataset = representative_data_gen
converter.target_spec.supported_ops = [tf.lite.OpsSet.TFLITE_BUILTINS_INT8]
converter.inference_input_type = tf.uint8
converter.inference_output_type = tf.uint8
tflite_model = converter.convert()
with open("model_int8.tflite", "wb") as f:
f.write(tflite_model)
command to run the inference with model_int8.tflite
$ USE_GPU_INFERENCE=0 \
python3 label_image.py -m model_int8.tflite \
-e /usr/lib/liblitert_vx_delegate.so
please help me if these steps correct.
all the above steps from the chatgpt.
4 返答(返信)
730件の閲覧回数
pengyong_zhang
Hi @subbareddyai
I will be on vacation for a week and may not reply during this period. If you are in a hurry, you can create a new ticket. My other colleagues will support you. Thanks for your understand.
B.R
720件の閲覧回数
subbareddyai
Thanks for the reply.
I will try to create new ticket on this meanwhile after your vacation please support here.
Thanks and Regards,
GV Subba Reddy
773件の閲覧回数
pengyong_zhang
757件の閲覧回数
subbareddyai
I tried converting using eiq tool and tflite. conversion with qunatization and int8  is success(Refer attached image for quantization settings that I have used for conversion) but when I use the tflite model with inference its saying the below error
Failed to load delegate or model with delegate. Trying without delegate. Error: Didn't find op for builtin opcode 'EXP' version '2'. An older version of this builtin might be supported. Are you using an old TFLite binary with a newer model?
Registration failed.
Traceback (most recent call last):
File "inference_quant_int8.py", line 50, in <module>
interpreter = Interpreter(model_path=MODEL_PATH, experimental_delegates=[delegate])
File "/home/root/miniforge3/envs/tflite/lib/python3.8/site-packages/tflite_runtime/interpreter.py", line 455, in __init__
_interpreter_wrapper.CreateWrapperFromFile(
ValueError: Didn't find op for builtin opcode 'EXP' version '2'. An older version of this builtin might be supported. Are you using an old TFLite binary with a newer model?
タグ(1)
%3CLINGO-SUB%20id%3D%22lingo-sub-2167437%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3Eimx8mp%20NPU%E3%82%92%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%99%E3%82%8BTensorflow%20Savedmodel%E3%81%8B%E3%82%89tflite%E3%81%B8%E3%81%AE%E5%A4%89%E6%8F%9B%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2167437%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%3C%2FP%3E%3CP%3ETensorflow%20Savedmodel%20%E3%82%92%E3%80%81imx8mp%20NPU%20%E3%82%92%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%99%E3%82%8B%20tflite%20%E3%83%A2%E3%83%87%E3%83%AB%E3%81%AB%E5%A4%89%E6%8F%9B%E3%81%97%E3%81%9F%E3%81%84%E3%81%A8%E6%80%9D%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E4%BB%A5%E4%B8%8B%E3%81%AE%E6%89%8B%E9%A0%86%E3%82%92%E8%A9%A6%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8C%E3%80%81%E3%81%86%E3%81%BE%E3%81%8F%E3%81%84%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%3C%2FP%3E%3CP%3EPython%20%E3%83%A2%E3%83%87%E3%83%AB%2F%E7%A0%94%E7%A9%B6%2F%E3%82%AA%E3%83%96%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E6%A4%9C%E5%87%BA%2F%E3%82%A8%E3%82%AF%E3%82%B9%E3%83%9D%E3%83%BC%E3%82%BF%E3%83%BC%E3%83%A1%E3%82%A4%E3%83%B3_v2.py%20%5C%3CBR%20%2F%3E%20--input_type%20%E7%94%BB%E5%83%8F%E3%83%86%E3%83%B3%E3%82%BD%E3%83%AB%20%5C%3CBR%20%2F%3E%20--pipeline_config_path%20%E3%83%88%E3%83%AC%E3%83%BC%E3%83%8B%E3%83%B3%E3%82%B0%E3%83%87%E3%82%A3%E3%83%AC%E3%82%AF%E3%83%88%E3%83%AA%2Fpipeline.config%20%5C%3CBR%20%2F%3E%20--trained_checkpoint_dir%20%E3%83%88%E3%83%AC%E3%83%BC%E3%83%8B%E3%83%B3%E3%82%B0%E3%83%87%E3%82%A3%E3%83%AC%E3%82%AF%E3%83%88%E3%83%AA%2F%E3%83%81%E3%82%A7%E3%83%83%E3%82%AF%E3%83%9D%E3%82%A4%E3%83%B3%E3%83%88%20%5C%3CBR%20%2F%3E%20--output_directory%20%E3%82%A8%E3%82%AF%E3%82%B9%E3%83%9D%E3%83%BC%E3%83%88%E3%81%95%E3%82%8C%E3%81%9F%E3%83%A2%E3%83%87%E3%83%AB%3C%2FP%3E%3CP%3E%E3%81%9D%E3%81%97%E3%81%A6%E3%80%81%E3%81%9D%E3%81%AE%E5%9B%BA%E5%AE%9A%E5%BD%A2%E7%8A%B6%E3%83%A2%E3%83%87%E3%83%AB%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%BE%E3%81%99%7B%3CBR%20%2F%3E%20SSD%20%7B%3CBR%20%2F%3E%E7%94%BB%E5%83%8F%E3%83%AA%E3%82%B5%E3%82%A4%E3%82%BA%20%7B%3CBR%20%2F%3E%E5%9B%BA%E5%AE%9A%E5%BD%A2%E7%8A%B6%E3%83%AA%E3%82%B5%E3%82%A4%E3%82%BA%20%7B%3CBR%20%2F%3E%E9%AB%98%E3%81%95%3A%20320%3CBR%20%2F%3E%E5%B9%85%3A%20320%3CBR%20%2F%3E%20%7D%3CBR%20%2F%3E%20%7D%3CBR%20%2F%3E%20%7D%3CBR%20%2F%3E%20%7D%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E3%81%BE%E3%81%9F%E3%80%81TFLite%E4%BA%92%E6%8F%9B%E3%81%AE%E3%82%AA%E3%83%9A%E3%83%AC%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%82%82%E7%A2%BA%E4%BF%9D%E3%81%99%E3%82%8B%3C%2FP%3E%3CP%3ESSD%20%7B%3CBR%20%2F%3E%E6%A9%9F%E8%83%BD%E6%8A%BD%E5%87%BA%E5%99%A8%20%7B%3CBR%20%2F%3E%E3%82%BF%E3%82%A4%E3%83%97%3A%20%22ssd_mobilenet_v2_fpn_keras%22%3CBR%20%2F%3E%20use_depthwise%3A%20true%3CBR%20%2F%3E%20%7D%3CBR%20%2F%3E%E3%83%9C%E3%83%83%E3%82%AF%E3%82%B9%E4%BA%88%E6%B8%AC%E5%AD%90%20%7B%3CBR%20%2F%3E%E7%95%B3%E3%81%BF%E8%BE%BC%E3%81%BF%E3%83%9C%E3%83%83%E3%82%AF%E3%82%B9%E4%BA%88%E6%B8%AC%E5%AD%90%20%7B%3CBR%20%2F%3E%20use_depthwise%3A%20true%3CBR%20%2F%3E%20%7D%3CBR%20%2F%3E%20%7D%3CBR%20%2F%3E%20%7D%3C%2FP%3E%3CP%3Etflite%E5%A4%89%E6%8F%9B%E3%82%B9%E3%82%AF%E3%83%AA%E3%83%97%E3%83%88%3C%2FP%3E%3CP%3ETensorflow%E3%82%92TF%E3%81%A8%E3%81%97%E3%81%A6%E3%82%A4%E3%83%B3%E3%83%9D%E3%83%BC%E3%83%88%E3%81%99%E3%82%8B%3CBR%20%2F%3E%E3%83%91%E3%82%B9%E3%83%A9%E3%82%A4%E3%83%96%E3%83%A9%E3%83%AA%E3%82%92%E3%82%A4%E3%83%B3%E3%83%9D%E3%83%BC%E3%83%88%E3%81%99%E3%82%8B%3C%2FP%3E%3CP%3Esaved_model_dir%20%3D%20%22%E3%82%A8%E3%82%AF%E3%82%B9%E3%83%9D%E3%83%BC%E3%83%88%E3%81%95%E3%82%8C%E3%81%9F%E3%83%A2%E3%83%87%E3%83%AB%2Fsaved_model%22%3C%2FP%3E%3CP%3E%E3%82%B3%E3%83%B3%E3%83%90%E3%83%BC%E3%82%BF%E3%83%BC%20%3D%20tf.lite.TFLiteConverter.from_saved_model(saved_model_dir)%3CBR%20%2F%3E%E3%82%B3%E3%83%B3%E3%83%90%E3%83%BC%E3%82%BF%E3%83%BC%E3%81%AE%E6%9C%80%E9%81%A9%E5%8C%96%3D%20%5Btf.lite.Optimize.DEFAULT%5D%3C%2FP%3E%3CP%3E%23%20INT8%E3%82%AD%E3%83%A3%E3%83%AA%E3%83%96%E3%83%AC%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E7%94%A8%E3%81%AE%E4%BB%A3%E8%A1%A8%E7%9A%84%E3%81%AA%E3%83%87%E3%83%BC%E3%82%BF%E3%82%BB%E3%83%83%E3%83%88%E3%82%92%E6%8F%90%E4%BE%9B%E3%81%99%E3%82%8B%3CBR%20%2F%3E%E4%BB%A3%E8%A1%A8%E3%83%87%E3%83%BC%E3%82%BF%E7%94%9F%E6%88%90()%E3%82%92%E5%AE%9A%E7%BE%A9%E3%81%97%E3%81%BE%E3%81%99%3A%3CBR%20%2F%3E%20data_dir%20%3D%20pathlib.Path(%22dataset%2Fval%22)%3CBR%20%2F%3E%20data_dir.glob(%22*.jpg%22)%20%E3%81%AE%20img_path%20%E3%81%AE%E5%A0%B4%E5%90%88%3A%3CBR%20%2F%3Eimg%20%3D%20tf.keras.preprocessing.image.load_img(img_path%2C%E3%82%BF%E3%83%BC%E3%82%B2%E3%83%83%E3%83%88%E3%82%B5%E3%82%A4%E3%82%BA%3D(320%2C%20320))%3CBR%20%2F%3E%20img%20%3D%20tf.keras.preprocessing.image.img_to_array(img)%3CBR%20%2F%3Eimg%20%3D%20img%5Btf.newaxis%2C...%5D%20%2F%20255.0%3CBR%20%2F%3E%20%5Bimg.astype(%22float32%22)%5D%20%E3%82%92%E7%94%9F%E6%88%90%E3%81%97%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3E%E3%82%B3%E3%83%B3%E3%83%90%E3%83%BC%E3%82%BF.representative_dataset%3D%20%E4%BB%A3%E8%A1%A8%E3%83%87%E3%83%BC%E3%82%BF%E7%94%9F%E6%88%90%3CBR%20%2F%3Econverter.target_spec.supported_ops%3D%20%5Btf.lite.OpsSet.TFLITE_BUILTINS_INT8%5D%3CBR%20%2F%3E%20converter.inference_input_type%3D%20tf.uint8%3CBR%20%2F%3Econverter.inference_output_type%3D%20tf.uint8%3C%2FP%3E%3CP%3Etflite_model%20%3D%20converter.convert()%3C%2FP%3E%3CP%3Eopen(%22model_int8.tflite%22%2C%20%E3%81%A7%22wb%22)%20%E3%82%92%20f%3A%20%E3%81%A8%E3%81%97%E3%81%A6%3CBR%20%2F%3Ef.write(tflite_model)%3C%2FP%3E%3CBR%20%2F%3E%3CP%3Emodel_int8.tflite%E3%81%A7%E6%8E%A8%E8%AB%96%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%99%E3%82%8B%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%3C%2FP%3E%3CP%3E%24%20USE_GPU_INFERENCE%3D0%20%5C%3CBR%20%2F%3E%20python3%20label_image.py%20-m%20model_int8.tflite%20%5C%3CBR%20%2F%3E%20-e%20%2Fusr%2Flib%2Fliblitert_vx_delegate.so%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E3%81%93%E3%82%8C%E3%82%89%E3%81%AE%E6%89%8B%E9%A0%86%E3%81%8C%E6%AD%A3%E3%81%97%E3%81%84%E3%81%8B%E3%81%A9%E3%81%86%E3%81%8B%E3%80%81%E5%8A%A9%E3%81%91%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%3CP%3E%E4%B8%8A%E8%A8%98%E3%81%AE%E3%81%99%E3%81%B9%E3%81%A6%E3%81%AE%E6%89%8B%E9%A0%86%E3%81%AF%E3%83%81%E3%83%A3%E3%83%83%E3%83%88%E3%82%B0%E3%83%AB%E3%83%BC%E3%83%97%E3%81%8B%E3%82%89%E5%AE%9F%E8%A1%8C%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2169449%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Tensorflow%20Savedmodel%20to%20tflite%20conversion%20which%20supports%20imx8mp%20NPU%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2169449%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%3C%2FP%3E%3CP%3E%E8%BF%94%E4%BF%A1%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%9D%E3%81%AE%E9%96%93%E3%80%81%E4%BC%91%E6%9A%87%E5%BE%8C%E3%81%AB%E6%96%B0%E3%81%97%E3%81%84%E3%83%81%E3%82%B1%E3%83%83%E3%83%88%E3%82%92%E4%BD%9C%E6%88%90%E3%81%97%E3%82%88%E3%81%86%E3%81%A8%E3%81%97%E3%81%BE%E3%81%99%E3%81%AE%E3%81%A7%E3%80%81%E3%81%93%E3%81%A1%E3%82%89%E3%81%A7%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3EGV%20%E3%82%B9%E3%83%90%E3%83%BB%E3%83%AC%E3%83%87%E3%82%A3%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2169341%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Tensorflow%20Savedmodel%20to%20tflite%20conversion%20which%20supports%20imx8mp%20NPU%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2169341%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F254707%22%20target%3D%22_blank%22%3E%40subbareddyai%3C%2FA%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3E1%E9%80%B1%E9%96%93%E4%BC%91%E6%9A%87%E3%82%92%E5%8F%96%E3%82%8B%E4%BA%88%E5%AE%9A%E3%81%AA%E3%81%AE%E3%81%A7%E3%80%81%E3%81%9D%E3%81%AE%E9%96%93%E3%81%AF%E8%BF%94%E4%BF%A1%E3%81%A7%E3%81%8D%E3%81%AA%E3%81%84%E3%81%8B%E3%82%82%E3%81%97%E3%82%8C%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E3%81%8A%E6%80%A5%E3%81%8E%E3%81%AE%E5%A0%B4%E5%90%88%E3%81%AF%E3%80%81%E6%96%B0%E3%81%97%E3%81%84%E3%83%81%E3%82%B1%E3%83%83%E3%83%88%E3%82%92%E4%BD%9C%E6%88%90%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%82%82CAN%E3%80%82%E4%BB%96%E3%81%AE%E5%90%8C%E5%83%9A%E3%82%82%E3%81%82%E3%81%AA%E3%81%9F%E3%82%92%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E3%81%94%E7%90%86%E8%A7%A3%E3%81%84%E3%81%9F%E3%81%A0%E3%81%8D%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3EBR%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2167799%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Tensorflow%20Savedmodel%20to%20tflite%20conversion%20which%20supports%20imx8mp%20NPU%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2167799%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3Eeiq%E3%83%84%E3%83%BC%E3%83%AB%E3%81%A8tflite%E3%82%92%E4%BD%BF%E3%81%A3%E3%81%A6%E5%A4%89%E6%8F%9B%E3%81%97%E3%81%A6%E3%81%BF%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E9%87%8F%E5%AD%90%E5%8C%96%E3%81%A8int8%E3%81%AB%E3%82%88%E3%82%8B%E5%A4%89%E6%8F%9B%E3%81%AF%E6%88%90%E5%8A%9F%E3%81%97%E3%81%BE%E3%81%99%EF%BC%88%E5%A4%89%E6%8F%9B%E3%81%AB%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%9F%E9%87%8F%E5%AD%90%E5%8C%96%E8%A8%AD%E5%AE%9A%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E3%81%AF%E6%B7%BB%E4%BB%98%E7%94%BB%E5%83%8F%E3%82%92%E5%8F%82%E7%85%A7%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%EF%BC%89%E3%81%8C%E3%80%81%E6%8E%A8%E8%AB%96%E3%81%A7tflite%E3%83%A2%E3%83%87%E3%83%AB%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81%E4%BB%A5%E4%B8%8B%E3%81%AE%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%8C%E8%A1%A8%E7%A4%BA%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%83%87%E3%83%AA%E3%82%B2%E3%83%BC%E3%83%88%E3%81%BE%E3%81%9F%E3%81%AF%E3%83%87%E3%83%AA%E3%82%B2%E3%83%BC%E3%83%88%E3%82%92%E5%90%AB%E3%82%80%E3%83%A2%E3%83%87%E3%83%AB%E3%81%AE%E8%AA%AD%E3%81%BF%E8%BE%BC%E3%81%BF%E3%81%AB%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E5%A7%94%E4%BB%BB%E3%81%AA%E3%81%97%E3%81%A7%E8%A9%A6%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%82%A8%E3%83%A9%E3%83%BC%3A%20%E7%B5%84%E3%81%BF%E8%BE%BC%E3%81%BF%E3%82%AA%E3%83%9A%E3%82%B3%E3%83%BC%E3%83%89%E3%80%8CEXP%E3%80%8D%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%E3%80%8C2%E3%80%8D%E3%81%AE%E3%82%AA%E3%83%9A%E3%82%B3%E3%83%BC%E3%83%89%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%E3%80%82%E3%81%93%E3%81%AE%E7%B5%84%E3%81%BF%E8%BE%BC%E3%81%BF%E9%96%A2%E6%95%B0%E3%81%AE%E5%8F%A4%E3%81%84%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%E3%81%8C%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E5%8F%AF%E8%83%BD%E6%80%A7%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%E6%96%B0%E3%81%97%E3%81%84%E3%83%A2%E3%83%87%E3%83%AB%E3%81%A7%E5%8F%A4%E3%81%84%20TFLite%20%E3%83%90%E3%82%A4%E3%83%8A%E3%83%AA%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%81%8B%3F%3CBR%20%2F%3E%E7%99%BB%E9%8C%B2%E3%81%AB%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3E%E3%83%88%E3%83%AC%E3%83%BC%E3%82%B9%E3%83%90%E3%83%83%E3%82%AF%EF%BC%88%E6%9C%80%E6%96%B0%E3%81%AE%E5%91%BC%E3%81%B3%E5%87%BA%E3%81%97%E3%81%8C%E6%9C%80%E5%BE%8C%EF%BC%89%3A%3CBR%20%2F%3E%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%80%8Cinference_quant_int8.py%E3%80%8D%E3%80%81%3CMODULE%3E%20%E3%81%AE%2050%20%E8%A1%8C%E7%9B%AE%3CBR%20%2F%3E%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%97%E3%83%AA%E3%82%BF%E3%83%BC%20%3D%20%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%97%E3%83%AA%E3%82%BF%E3%83%BC(model_path%3DMODEL_PATH%2C%20experimental_delegates%3D%5B%E3%83%87%E3%83%AA%E3%82%B2%E3%83%BC%E3%83%88%5D)%3CBR%20%2F%3E%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%20%22%2F%E3%83%9B%E3%83%BC%E3%83%A0%2Froot%2Fminiforge3%2Fenvs%2Ftflite%2Flib%2Fpython3.8%2Fsite-%E3%83%91%E3%83%83%E3%82%B1%E3%83%BC%E3%82%B8%2Ftflite_runtime%2Finterpreter.py%22%2C__init__%E3%81%AE%20455%20%E8%A1%8C%E7%9B%AE%3CBR%20%2F%3E_interpreter_wrapper.CreateWrapperFromFile()%3CBR%20%2F%3E%20ValueError%3A%20%E7%B5%84%E3%81%BF%E8%BE%BC%E3%81%BF%E3%82%AA%E3%83%9A%E3%82%B3%E3%83%BC%E3%83%89%E3%80%8CEXP%E3%80%8D%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%E3%80%8C2%E3%80%8D%E3%81%AE%E3%82%AA%E3%83%9A%E3%82%B3%E3%83%BC%E3%83%89%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%E3%80%82%E3%81%93%E3%81%AE%E7%B5%84%E3%81%BF%E8%BE%BC%E3%81%BF%E9%96%A2%E6%95%B0%E3%81%AE%E5%8F%A4%E3%81%84%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%E3%81%8C%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E5%8F%AF%E8%83%BD%E6%80%A7%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%E6%96%B0%E3%81%97%E3%81%84%E3%83%A2%E3%83%87%E3%83%AB%E3%81%A7%E5%8F%A4%E3%81%84%20TFLite%20%E3%83%90%E3%82%A4%E3%83%8A%E3%83%AA%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%81%8B%3F%3CBR%20%2F%3E%E7%99%BB%E9%8C%B2%E3%81%AB%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FMODULE%3E%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2167516%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Tensorflow%20Savedmodel%20to%20tflite%20conversion%20which%20supports%20imx8mp%20NPU%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2167516%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F254707%22%20target%3D%22_blank%22%3E%40subbareddyai%3C%2FA%3E%3C%2FP%3E%0A%3CP%3E%E5%BD%93%E7%A4%BE%E3%81%AE%20eIQ%20%E3%83%84%E3%83%BC%E3%83%AB%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%3CSPAN%3E%E3%83%A2%E3%83%87%E3%83%AB%E3%82%92%E5%A4%89%E6%8F%9B%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdesign%2Fdesign-center%2Fsoftware%2Feiq-ai-development-environment%2Feiq-toolkit-for-end-to-end-model-development-and-deployment%3AEIQ-TOOLKIT%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3Ehttps%3A%2F%2Fwww.nxp.com%2Fdesign%2Fdesign-center%2Fsoftware%2Feiq-ai-development-environment%2Feiq-toolkit-for-end-to-end-model-development-and-deployment%3AEIQ-TOOLKIT%3C%2FA%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3EBR%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E
