I am currently facing issues with imx6 processors with temperature raise by 45 Degree Celsius , when the CPU loaded with 12 to 16 % of usage.Mainly when we perform live streaming , this is reaching to maximum temp .
We measured the temperature of CPU through internal sensor values, and external DDRAM through an external temperature sensor.
I want to know what is the operating temperatures of Imx6 , with respect to CPU usage ? Till What value we can reduce the temperature by customizing our our design ?
Hi prakeerthi
please check
AN5381 Measuring Current in i.MX Applications
https://www.nxp.com/docs/en/application-note/AN5381.pdf
AN4579 i.MX 6 Series Thermal Management Guidelines
https://www.nxp.com/docs/en/application-note/AN4579.pdf
