TJA1103 with i.MX8MP
1,057 次查看
Wobaffet
Senior Contributor I
We'll be using TJA1103 for our custom board with i.MX8MP. Does pin-out for TJA1103 is same with TJA1100 series that used on other nxp evb's in terms of device tree? Do you have one example configuration for TJA1103 in particular? Thank you in advance.
Best Regards.
1,045 次查看
Bio_TICFSL
NXP don't have example but it is working at the same clock frequency it going to work with current dtb.
regards
1,046 次查看
Bio_TICFSL
regards
