System hangs when building QTWebEnginem
hankwang
Contributor V
Hey,
        We want to build 6.6.23 and include QT6.7. We have added qtwebenigne to the BSP and masked the meta-chromium recipe.
        When the system bitbake qtwebenigne, the system will hang. But my system has 32G RAM.
        Bitbake thread set 4.
        How to set up an environment for compiling qtwebengine?
hankwang
Contributor V
I solved this problem. SWAP can be modified from the default 2G to 8G.
hankwang
Contributor V
hankwang
Contributor V
Regarding step 3: Added the following information, set thread 8.
BB_NUMBER_THREADS="8"
PARALLEL_MAKE = "-j 8"
jimmychan
Are you using Ubuntu? How many cpu core in your system?
hankwang
Contributor V
I set threads to 8.But I still can't bitbake qtwebenigine.
bitbake's do_compile progress is still stay at 0%.
jimmychan
Could you show me the steps so I can try it on my side?
Is there any error message? where is it stop?
hankwang
Contributor V
The step is very simple.
1. Download BSP 6.6.23 BSP from NXP.
2. DISTRO=fsl-imx-xwayland MACHINE=imx8mm-lpddr4-evk source imx-setup-release.sh -b
build-xwayland
3. Modify the local.conf (set thread to
4. Add IMAGE_INSTALL:append = " packagegroup-qt6-webengine" in local.conf
5. Mask #BBLAYERS += "${BSPDIR}/sources/meta-browser/meta-chromium" in bblayer.conf
6.bitbake imx-image-full
jimmychan
Your host system is good enough to build the BSP.
In the conf/local.conf, please try to add below:
hankwang
Contributor V
Yes, I use Ubuntu 20.04. The Core has 16.
hankwang
Contributor V
I monitor memory usage. 32G memory becomes empty. Do you have any idea?  We can reduce the memory usage or how we need to increase the memory size.
%3CLINGO-SUB%20id%3D%22lingo-sub-1956308%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ESystem%20hangs%20when%20building%20QTWebEnginem%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1956308%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHey%2C%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20We%20want%20to%20build%206.6.23%20and%20include%20QT6.7.%20We%20have%20added%20qtwebenigne%20to%20the%20BSP%20and%20masked%20the%20meta-chromium%20recipe.%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20When%20the%20system%20bitbake%20qtwebenigne%2C%20the%20system%20will%20hang.%20But%20my%20system%20has%2032G%20RAM.%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20Bitbake%20thread%20set%204.%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20How%20to%20set%20up%20an%20environment%20for%20compiling%20qtwebengine%3F%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-1956308%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3Ei.MX%208M%20%7C%20i.MX%208M%20Mini%20%7C%20i.MX%208M%20Nano%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1958231%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20System%20hangs%20when%20building%20QTWebEnginem%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1958231%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EI%20solved%20this%20problem.%20SWAP%20can%20be%20modified%20from%20the%20default%202G%20to%208G.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1958155%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20System%20hangs%20when%20building%20QTWebEnginem%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1958155%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3ERegarding%20step%203%3A%20Added%20the%20following%20information%2C%20set%20thread%208.%3C%2FP%3E%3CP%3EBB_NUMBER_THREADS%3D%228%22%3C%2FP%3E%3CP%3EPARALLEL_MAKE%20%3D%20%22-j%208%22%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1958152%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20System%20hangs%20when%20building%20QTWebEnginem%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1958152%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EThe%20step%20is%20very%20simple.%3C%2FP%3E%3CP%3E1.%20Download%20BSP%206.6.23%20BSP%20from%20NXP.%3C%2FP%3E%3CP%3E2.%20DISTRO%3Dfsl-imx-xwayland%20MACHINE%3Dimx8mm-lpddr4-evk%20source%20imx-setup-release.sh%20-b%3CBR%20%2F%3Ebuild-xwayland%3C%2FP%3E%3CP%3E3.%20Modify%20the%20local.conf%20(set%20thread%20to%20%3CLI-EMOJI%20id%3D%22lia_smiling-face-with-sunglasses%22%20title%3D%22%3Asmiling_face_with_sunglasses%3A%22%3E%3C%2FLI-EMOJI%3E%3C%2FP%3E%3CP%3E4.%20Add%20IMAGE_INSTALL%3Aappend%20%3D%20%22%20packagegroup-qt6-webengine%22%20in%20local.conf%3C%2FP%3E%3CP%3E5.%20Mask%20%23BBLAYERS%20%2B%3D%20%22%24%7BBSPDIR%7D%2Fsources%2Fmeta-browser%2Fmeta-chromium%22%20in%20bblayer.conf%3C%2FP%3E%3CP%3E6.bitbake%20imx-image-full%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1957256%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20System%20hangs%20when%20building%20QTWebEnginem%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1957256%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3ECould%20you%20show%20me%20the%20steps%20so%20I%20can%20try%20it%20on%20my%20side%3F%3C%2FP%3E%0A%3CP%3EIs%20there%20any%20error%20message%3F%20where%20is%20it%20stop%3F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1956504%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20System%20hangs%20when%20building%20QTWebEnginem%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1956504%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EI%20set%20threads%20to%208.But%20I%20still%20can't%20bitbake%20qtwebenigine.%3C%2FP%3E%3CP%3Ebitbake's%20do_compile%20progress%20is%20still%20stay%20at%200%25.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1956486%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20System%20hangs%20when%20building%20QTWebEnginem%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1956486%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EYour%20host%20system%20is%20good%20enough%20to%20build%20the%20BSP.%3C%2FP%3E%0A%3CP%3EIn%20the%20conf%2Flocal.conf%2C%20please%20try%20to%20add%20below%3A%3C%2FP%3E%0A%3CP%3EBB_NUMBER_THREADS%3D%228%22%3C%2FP%3E%0A%3CP%3EPARALLEL_MAKE%20%3D%20%22-j%208%22%3C%2FP%3E%0A%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1956469%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20System%20hangs%20when%20building%20QTWebEnginem%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1956469%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EYes%2C%20I%20use%20Ubuntu%2020.04.%20The%20Core%20has%2016.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1956467%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20System%20hangs%20when%20building%20QTWebEnginem%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1956467%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EAre%20you%20using%20Ubuntu%3F%20How%20many%20cpu%20core%20in%20your%20system%3F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1956387%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20System%20hangs%20when%20building%20QTWebEnginem%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1956387%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EI%20monitor%20memory%20usage.%2032G%20memory%20becomes%20empty.%20Do%20you%20have%20any%20idea%3F%26nbsp%3B%20We%20can%20reduce%20the%20memory%20usage%20or%20how%20we%20need%20to%20increase%20the%20memory%20size.%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22hankwang_0-1726646171107.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22hankwang_0-1726646171107.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F299640i8DE2D110D88F2A22%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22hankwang_0-1726646171107.png%22%20alt%3D%22hankwang_0-1726646171107.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E
