System hangs when building QTWebEnginem
5,325件の閲覧回数
hankwang
Hey,
        We want to build 6.6.23 and include QT6.7. We have added qtwebenigne to the BSP and masked the meta-chromium recipe.
        When the system bitbake qtwebenigne, the system will hang. But my system has 32G RAM.
        Bitbake thread set 4.
        How to set up an environment for compiling qtwebengine?
5,249件の閲覧回数
hankwang
I solved this problem. SWAP can be modified from the default 2G to 8G.
9 返答(返信)
5,250件の閲覧回数
hankwang
5,250件の閲覧回数
hankwang
Regarding step 3: Added the following information, set thread 8.
BB_NUMBER_THREADS="8"
PARALLEL_MAKE = "-j 8"
5,299件の閲覧回数
jimmychan
Are you using Ubuntu? How many cpu core in your system?
5,277件の閲覧回数
hankwang
I set threads to 8.But I still can't bitbake qtwebenigine.
bitbake's do_compile progress is still stay at 0%.
5,271件の閲覧回数
jimmychan
Could you show me the steps so I can try it on my side?
Is there any error message? where is it stop?
5,243件の閲覧回数
hankwang
The step is very simple.
1. Download BSP 6.6.23 BSP from NXP.
2. DISTRO=fsl-imx-xwayland MACHINE=imx8mm-lpddr4-evk source imx-setup-release.sh -b
build-xwayland
3. Modify the local.conf (set thread to
4. Add IMAGE_INSTALL:append = " packagegroup-qt6-webengine" in local.conf
5. Mask #BBLAYERS += "${BSPDIR}/sources/meta-browser/meta-chromium" in bblayer.conf
6.bitbake imx-image-full
5,282件の閲覧回数
jimmychan
Your host system is good enough to build the BSP.
In the conf/local.conf, please try to add below:
5,286件の閲覧回数
hankwang
Yes, I use Ubuntu 20.04. The Core has 16.
5,295件の閲覧回数
hankwang
I monitor memory usage. 32G memory becomes empty. Do you have any idea?  We can reduce the memory usage or how we need to increase the memory size.
%3CLINGO-SUB%20id%3D%22lingo-sub-1956308%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EQTWebEnginem%E3%81%AE%E3%83%93%E3%83%AB%E3%83%89%E6%99%82%E3%81%AB%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%81%8C%E3%83%8F%E3%83%B3%E3%82%B0%E3%82%A2%E3%83%83%E3%83%97%E3%81%99%E3%82%8B%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1956308%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%AD%E3%81%88%3C%2FP%3E%3CP%3E6.6.23%20%E3%82%92%E3%83%93%E3%83%AB%E3%83%89%E3%81%97%E3%80%81QT6.7%20%E3%82%92%E5%90%AB%E3%82%81%E3%81%9F%E3%81%84%E3%81%A8%E8%80%83%E3%81%88%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82BSP%E3%81%ABqtwebenigne%E3%82%92%E8%BF%BD%E5%8A%A0%E3%81%97%E3%80%81%E3%83%A1%E3%82%BF%E3%82%AF%E3%83%AD%E3%83%A0%E3%83%AC%E3%82%B7%E3%83%94%E3%82%92%E3%83%9E%E3%82%B9%E3%82%AF%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3E%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%81%8C%20qtwebenigne%20%E3%82%92%E3%83%93%E3%83%83%E3%83%88%E3%83%99%E3%82%A4%E3%82%AF%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%81%8C%E3%83%8F%E3%83%B3%E3%82%B0%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E3%81%97%E3%81%8B%E3%81%97%E3%80%81%E7%A7%81%E3%81%AE%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%81%AB%E3%81%AF32G%E3%81%AERAM%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3EBitbake%E3%82%B9%E3%83%AC%E3%83%83%E3%83%89%E3%82%BB%E3%83%83%E3%83%884%E3%80%82%3C%2FP%3E%3CP%3Eqtwebengine%E3%82%92%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%AB%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AE%E7%92%B0%E5%A2%83%E3%82%92%E8%A8%AD%E5%AE%9A%E3%81%99%E3%82%8B%E3%81%AB%E3%81%AF%E3%81%A9%E3%81%86%E3%81%99%E3%82%8C%E3%81%B0%E3%82%88%E3%81%84%E3%81%A7%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-1956308%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3Ei.MX%208M%20%7C%20i.MX%208M%20Mini%20%7C%20i.MX%208M%20Nano%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1958231%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3AQTWebEnginem%E3%81%AE%E3%83%93%E3%83%AB%E3%83%89%E6%99%82%E3%81%AB%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%81%8C%E3%83%8F%E3%83%B3%E3%82%B0%E3%81%97%E3%81%BE%E3%81%99%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1958231%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%81%AE%E5%95%8F%E9%A1%8C%E3%82%92%E8%A7%A3%E6%B1%BA%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82SWAP%E3%81%AF%E3%83%87%E3%83%95%E3%82%A9%E3%83%AB%E3%83%88%E3%81%AE2G%E3%81%8B%E3%82%898G%E3%81%AB%E5%A4%89%E6%9B%B4%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1958155%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3AQTWebEnginem%E3%81%AE%E3%83%93%E3%83%AB%E3%83%89%E6%99%82%E3%81%AB%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%81%8C%E3%83%8F%E3%83%B3%E3%82%B0%E3%81%97%E3%81%BE%E3%81%99%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1958155%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%82%B9%E3%83%86%E3%83%83%E3%83%973%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%3A%E6%AC%A1%E3%81%AE%E6%83%85%E5%A0%B1%E3%82%92%E8%BF%BD%E5%8A%A0%E3%81%97%E3%80%81%E3%82%B9%E3%83%AC%E3%83%83%E3%83%898%E3%82%92%E8%A8%AD%E5%AE%9A%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3EBB_NUMBER_THREADS%3D%228%22%3C%2FP%3E%3CP%3EPARALLEL_MAKE%20%3D%20%22-j%208%22%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1958152%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3AQTWebEnginem%E3%81%AE%E3%83%93%E3%83%AB%E3%83%89%E6%99%82%E3%81%AB%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%81%8C%E3%83%8F%E3%83%B3%E3%82%B0%E3%81%97%E3%81%BE%E3%81%99%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1958152%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%89%8B%E9%A0%86%E3%81%AF%E9%9D%9E%E5%B8%B8%E3%81%AB%E7%B0%A1%E5%8D%98%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E1.%20NXP%E3%81%8B%E3%82%89BSP%206.6.23%20BSP%E3%82%92%E3%83%80%E3%82%A6%E3%83%B3%E3%83%AD%E3%83%BC%E3%83%89%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E2.%20DISTRO%3Dfsl-imx-xwayland%20MACHINE%3Dimx8mm-lpddr4-evk%20%E3%82%BD%E3%83%BC%E3%82%B9%20imx-setup-release.sh%20-b%3CBR%20%2F%3E%E3%83%93%E3%83%AB%E3%83%89-xwayland%3C%2FP%3E%3CP%3E3.%20local.conf%20%E3%82%92%E5%A4%89%E6%9B%B4%E3%81%97%E3%81%BE%E3%81%99%20(thread%20%E3%82%92%20%3CLI-EMOJI%20id%3D%22lia_smiling-face-with-sunglasses%22%20title%3D%22%3Asmiling_face_with_sunglasses%3A%22%3E%3C%2FLI-EMOJI%3E%3C%2FP%3E%3CP%3E4.%20local.conf%20%E3%81%AB%20IMAGE_INSTALL%3Aappend%20%3D%20%22%20packagegroup-qt6-webengine%22%20%E3%82%92%E8%BF%BD%E5%8A%A0%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E5.%20bblayer.conf%20%E3%81%A7%20%23BBLAYERS%20%2B%3D%20%22%24%7BBSPDIR%7D%2Fsources%2Fmeta-browser%2Fmeta-chromium%22%20%E3%82%92%E3%83%9E%E3%82%B9%E3%82%AF%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E6.%E3%83%93%E3%83%83%E3%83%88%E3%83%99%E3%82%A4%E3%82%AFimx-image-full%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1957256%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3AQTWebEnginem%E3%81%AE%E3%83%93%E3%83%AB%E3%83%89%E6%99%82%E3%81%AB%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%81%8C%E3%83%8F%E3%83%B3%E3%82%B0%E3%81%97%E3%81%BE%E3%81%99%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1957256%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E7%A7%81%E3%81%AE%E5%81%B4%E3%81%A7%E8%A9%A6%E3%81%99%E3%81%93%E3%81%A8%E3%81%8C%E3%81%A7%E3%81%8D%E3%82%8B%E3%82%88%E3%81%86%E3%81%AB%E3%80%81%E6%89%8B%E9%A0%86%E3%82%92%E6%95%99%E3%81%88%E3%81%A6%E3%82%82%E3%82%89%E3%81%88%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%0A%3CP%3E%E3%82%A8%E3%83%A9%E3%83%BC%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%3F%E3%81%A9%E3%81%93%E3%81%A7%E6%AD%A2%E3%81%BE%E3%82%8B%E3%81%AE%3F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1956504%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3AQTWebEnginem%E3%81%AE%E3%83%93%E3%83%AB%E3%83%89%E6%99%82%E3%81%AB%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%81%8C%E3%83%8F%E3%83%B3%E3%82%B0%E3%81%97%E3%81%BE%E3%81%99%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1956504%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%82%B9%E3%83%AC%E3%83%83%E3%83%89%E3%82%928%E3%81%AB%E8%A8%AD%E5%AE%9A%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8C%E3%80%81%E3%81%BE%E3%81%A0qtwebenigine%E3%82%92%E3%83%93%E3%83%83%E3%83%88%E3%83%99%E3%82%A4%E3%82%AF%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%AF%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%3CP%3EBitbake%E3%81%AEdo_compile%E9%80%B2%E6%8D%97%E3%81%AF%E3%81%BE%E3%81%A00%25%E3%81%AB%E3%81%A8%E3%81%A9%E3%81%BE%E3%81%A3%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1956486%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3AQTWebEnginem%E3%81%AE%E3%83%93%E3%83%AB%E3%83%89%E6%99%82%E3%81%AB%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%81%8C%E3%83%8F%E3%83%B3%E3%82%B0%E3%81%97%E3%81%BE%E3%81%99%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1956486%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%83%9B%E3%82%B9%E3%83%88%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%81%AF%E3%80%81BSP%20%E3%82%92%E3%83%93%E3%83%AB%E3%83%89%E3%81%99%E3%82%8B%E3%81%AE%E3%81%AB%E5%8D%81%E5%88%86%E3%81%AA%E6%80%A7%E8%83%BD%E3%82%92%E5%82%99%E3%81%88%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3Econf%2Flocal.conf%20%E3%81%A7%E3%80%81%E4%BB%A5%E4%B8%8B%E3%82%92%E8%BF%BD%E5%8A%A0%E3%81%97%E3%81%A6%E3%81%BF%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%0A%3CP%3EBB_NUMBER_THREADS%3D%228%22%3C%2FP%3E%0A%3CP%3EPARALLEL_MAKE%20%3D%20%22-j%208%22%3C%2FP%3E%0A%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1956469%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3AQTWebEnginem%E3%81%AE%E3%83%93%E3%83%AB%E3%83%89%E6%99%82%E3%81%AB%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%81%8C%E3%83%8F%E3%83%B3%E3%82%B0%E3%81%97%E3%81%BE%E3%81%99%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1956469%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%AF%E3%81%84%E3%80%81Ubuntu%2020.04%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%82%B3%E3%82%A2%E3%81%AB%E3%81%AF16%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1956467%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3AQTWebEnginem%E3%81%AE%E3%83%93%E3%83%AB%E3%83%89%E6%99%82%E3%81%AB%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%81%8C%E3%83%8F%E3%83%B3%E3%82%B0%E3%81%97%E3%81%BE%E3%81%99%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1956467%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EUbuntu%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%81%8B%3F%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%81%AB%E3%81%AF%E3%81%84%E3%81%8F%E3%81%A4%E3%81%AECPU%E3%82%B3%E3%82%A2%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1956387%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3AQTWebEnginem%E3%81%AE%E3%83%93%E3%83%AB%E3%83%89%E6%99%82%E3%81%AB%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%81%8C%E3%83%8F%E3%83%B3%E3%82%B0%E3%81%97%E3%81%BE%E3%81%99%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1956387%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%83%A1%E3%83%A2%E3%83%AA%E4%BD%BF%E7%94%A8%E9%87%8F%E3%82%92%E7%9B%A3%E8%A6%96%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%8232G%E3%83%A1%E3%83%A2%E3%83%AA%E3%81%8C%E7%A9%BA%E3%81%AB%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%E4%BD%95%E3%81%8B%E5%BF%83%E5%BD%93%E3%81%9F%E3%82%8A%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%3F%E3%83%A1%E3%83%A2%E3%83%AA%E4%BD%BF%E7%94%A8%E9%87%8F%E3%82%92%E6%B8%9B%E3%82%89%E3%81%99%E3%81%8B%E3%80%81%E3%83%A1%E3%83%A2%E3%83%AA%E3%82%B5%E3%82%A4%E3%82%BA%E3%82%92%E5%A2%97%E3%82%84%E3%81%99%E6%96%B9%E6%B3%95%E3%82%92%E6%B8%9B%E3%82%89%E3%81%99%E3%81%93%E3%81%A8%E3%81%8C%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22hankwang_0-1726646171107.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22hankwang_0-1726646171107.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F299640i8DE2D110D88F2A22%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22hankwang_0-1726646171107.png%22%20alt%3D%22hankwang_0-1726646171107.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E
