Hi Champs
Could you please let us know if iMX 8/8X/8X Plus able to support 2x MII (Media Independant Interface) ?
I found those devices have "2 x Gbit/s Ethernet with IEEE 1588, AVB, IEEE 802.;1Oav, 1x also with TSN in case 8X Plus.
We would like to use 2x (R)MII using iMX8 seriese that support 1.xGHz clock speed with multi-core AP.
James
Solved! Go to Solution.
refer to the imx8qm data sheet:
ethernet cotroller supports:
2× 1 Gbps Ethernet controllers supporting RGMII + AVB (Audio Video Bridging,
IEEE 802.1Qav)
IEEE 802.1Qav)
