Hi team
May I ask which 4G LTE M.2/mini-PCIe interface modules have been verified on Windows 10 IoT? I would like to verify them on the IMX8MQ EVK and IMX8MP EVK.
Thaknks for helps
James
Solved! Go to Solution.
All i.MX8 have been validate to work with PCIe, we have not tested the LTE for 4G but check the errata of this WinIoT version, Limitation: PCIe DMA supports 32-bit addressing only.
Connected PCIe devices using memory > 4 GB may work
incorrectly. Workaround: Allocate memory for PCIe devices
below 4G or copy data to lower address space in the device
driver. More information:
https://www.nxp.com/docs/en/release-note/IMXWNR.pdf
Hi Bio_TICHSL,
Thanks for yuor reply.
Does NXP have a testing plan for 4G LTE / 5G modules on Windows 10 IoT?
So far, there is nothing on the schedule.
