Support for 4G LTE module with i.MX8M series in Windows 10 IoT
1,931件の閲覧回数
james_lin
Hi team
May I ask which 4G LTE M.2/mini-PCIe interface modules have been verified on Windows 10 IoT? I would like to verify them on the IMX8MQ EVK and IMX8MP EVK.
Thaknks for helps
James
1,857件の閲覧回数
Bio_TICFSL
So far, there is nothing on the schedule.
3 返答(返信)
1,886件の閲覧回数
Bio_TICFSL
All i.MX8 have been validate to work with PCIe, we have not tested the LTE for 4G but check the errata of this WinIoT version, Limitation: PCIe DMA supports 32-bit addressing only.
Connected PCIe devices using memory > 4 GB may work
incorrectly. Workaround: Allocate memory for PCIe devices
below 4G or copy data to lower address space in the device
driver. More information:
https://www.nxp.com/docs/en/release-note/IMXWNR.pdf
1,881件の閲覧回数
james_lin
Hi Bio_TICHSL,
Thanks for yuor reply.
Does NXP have a testing plan for 4G LTE / 5G  modules on Windows 10 IoT?
1,858件の閲覧回数
Bio_TICFSL
