Can anyone help me ...what is the procedure to add vlc plugins to the browser......
Bhavana, I think you find answer in google, please use control words VLC and ActiveX.
As example my code for JQuery:
* @brief view RTSP-stream
* @param[in] target output element
* @param[in] stream stream type (H264, MJPEG, ...)
* @return nothing
* @remarks now not work in InternetExplorer
function runVLC(target, stream)
var support = true
var addr = 'rtsp://' + window.location.hostname + stream
if ($.browser.msie) {
$(target).html('<object type = "application/x-vlc-plugin" ' +
'version = "VideoLAN.VLCPlugin.2" ' +
'classid = "clsid:9BE31822-FDAD-461B-AD51-BE1D1C159921" ' +
'events = "True" id = "vlc"></object>')
$(target + ' object').css({'width': '100%', 'height': '100%'})
} else if ($.browser.mozilla || $.browser.webkit) {
$(target).html('<embed type = "application/x-vlc-plugin" ' +
'width = "100%" height = "100%" ' +
'id = "vlc" text = "Please install VLC player">' +
'</embed>')
} else {
support = false
$(target).html('Not supported browser!')
if (support) {
var vlc = document.getElementById('vlc')
if (vlc) {
var opt = new Array(':network-caching=300')
try {
var id = vlc.playlist.add(addr, '', opt)
vlc.playlist.playItem(id)
} catch (e) {
$(target).empty().html('<div id = "error">Error: ' + e +
'<br>URL: ' + addr + '</div>')
