State of ov5640_mipi camera from command line?
1,602件の閲覧回数
gbiradar
Hi Guys,
               I'm trying to know the state of ov5640_mipi camera from command line, As i know that initially camera will be in standby mode until unless we run application(mxc_v4l2_capture).
Is their any way to know whether camera in standby mode/ wakeup mode.
I have already checked
cat /sys/kernel/debug/gpio // here mipi gpio state is not changing while before and after streaming through application.
thanks & regards,
Ganesh Biradar
タグ(4)
1,415件の閲覧回数
alejandrolozan1
After delving into this I think lsof /dev/video0 should find the process which has the webcam. Maybe that helps.
Alejandro
1,415件の閲覧回数
gbiradar
Coming to /dev/video0 is for parallel camera and /dev/video1 is mipi camera i can see that by ls /dev/video*.
But i need support  to know is their any support available in ov5640_mipi for sleep and wakeup mode if so how do i know the state & how can i change state of camera from command line.
If their is no support how do i add support for this. when i call wakeup, camera should be ready to capture.
In sleep mode, camera should go to sleep.
thanks & regards,
Ganesh Biradar
