Starting boot-up procedure halts for TQ-Systems i.MX8MPlus TQMa8MPxL
Sameer_Kelaskar
    We are using a customized board based on TQ-Systems i.MX8MPlus TQMa8MPxL - MBa8MPxL. Also we prepared the Yocto BSP Build procedure and our board powers on but at as we connect serial terminal we get following boot log as given in attachment below and the boot procedure halts at the end of the log.
    Any suggestions would be helpful.
Sameer_Kelaskar
The boot-up procedure now works properly problem solved. Thank you for replies, we will keep these useful points noted for any further use.
Sameer_Kelaskar
The main SoM module we used is - TQMa8MPQL
SoM module reference - https://www.tq-group.com/en/products/tq-embedded/arm-architecture/tqma8mpxl/
While we are using the carrier board - MBa8MPxL
Carrier board reference - https://www.tq-group.com/en/products/tq-embedded/arm-architecture/stka8mpxl/
joanxie
since this isn't customized board, this is the third party company board, you should boot up successfully if you use default image they offered, I suggest that you can contact them to get further help, did you use images offered by TQ?
joanxie
what your board based on? did you design your board based on NXP IMX8MP EVK board? if you couldn't confirm your HW design is correct, pls create a new case, upload your schematic, let HW engineer double check it
