Start Up configuration of PMIC MC32PF3000A2EP for IMX7D
Search instead for
logeshs
We used MC32PF3000A2EP in our one of the IOT products.
In that as per datasheet Page 35 and the Table 42. Start-up configuration clarity is required.
The confusion is between default configuration and Pre Programmed OTP configuration.
1. MC32PF3000A2 (A2 series part supports our required configuration votlages) customized start-up configuration directly from the factory? Or we need to program the chip ?
2. At first power on , the chip is it in the default configuration or pre programmed OTP configuration? What will be the output voltages for the part MC32PF3000A2EP ?
Logesh
Yuri
  The MC32PF3000A2 is factory pre-programmed part.
2.
  The chip (A2) is in the pre-programmed OTP configuration at first power on.
Yuri
