Sound turns bad after pause/resume with totem player.
franklee19731
Hi guys,
    Out test team report a bug about totem player in Ubuntu, iMX6DL platform, it is derived from SABRESD board.
    This problem will occur when I pause a playing video clip,  and resume again, or drag the "time" progress bar, the sound turn not fluent as before, and the same thing happened with player written by ourself, so I think this may be caused by a certain plugin.
    There is a sample clip in the attachment, but the problem is not only occurred  with this clip.
regards
Frank
Labels (4)
CommunityBot
Community Manager
This an automatic process.
We are marking this post as solved, due to the either low activity or any reply marked as correct.
If you have additional questions, please create a new post and reference to this closed post.
NXP Community!
CommunityBot
Community Manager
NXP Community!
YixingKong
Senior Contributor IV
Frank
We have not got your response yet and will close the discussion in 3 days. If you still need help, please feel free to reply with an update to this discussion.
Yixing
YixingKong
Frank, has your issue been answered? If yes, could we close the discussion?
Yixing
franklee19731
BTW: The Freescale gstreamer plugin's version is 3.0.7.
xiaoqianlin
We verified there was no such issue on MX6SDP board which uses WOLFSON AUDIO CODEC.
Linda Lin
xiaoqianlin
sudo apt-get install pulseaudio. After installed pulseaudio, this issue is there.
Linda Lin
franklee1973
By the help from Linda, I find the bug is in the audio codec IC driver, there is not the bug of gstreamer plugins, thanks for people that provide helps.
franklee19731
I made a mistake. I removed pulseaudio before I changed audio codec driver, sound is good. But today I installed pulseaudio, the sound turns bad again.
