These days I am building qt4.8.5 for imx6q,and had some questions.
My BSP is Linux-3.10.17,and the type of hardware is imx6q-rom3420,and i am using yocto project.
When I build qt4.8.5,always failed.
The log is :
Creating qmake. Please wait...
make: Nothing to be done for `first'.
You have not explicitly asked to use pkg-config and are cross-compiling.
pkg-config will not be used to automatically query cflag/lib parameters for
dependencies
floatmath auto-detection... ()
/home/parallels/work31017/qt-everywhere-opensource-src-4.8.5/bin/qmake: 1: /home/parallels/work31017/qt-everywhere-opensource-src-4.8.5/bin/qmake: Syntax error: word unexpected (expecting ")")
make: *** No targets specified and no makefile found. Stop.
floatmath disabled.
mmx auto-detection... ()
mmx disabled.
3dnow auto-detection... ()
3dnow disabled.
sse auto-detection... ()
sse disabled.
sse2 auto-detection... ()
sse2 disabled.
sse3 auto-detection... ()
sse3 disabled.
ssse3 auto-detection... ()
ssse3 disabled.
sse4_1 auto-detection... ()
sse4_1 disabled.
sse4_2 auto-detection... ()
sse4_2 disabled.
avx auto-detection... ()
avx disabled.
neon auto-detection... ()
neon disabled.
ipc_sysv auto-detection... ()
ipc_sysv disabled.
ipc_posix auto-detection... ()
ipc_posix disabled.
libtiff auto-detection... ()
libtiff disabled.
libmng auto-detection... ()
libmng disabled.
DB2 auto-detection... ()
DB2 disabled.
InterBase auto-detection... ()
InterBase disabled.
MySQL (thread-safe) auto-detection... ()
MySQL (thread-safe) disabled.
MySQL (thread-unsafe) auto-detection... ()
MySQL (thread-unsafe) disabled.
OCI auto-detection... ()
OCI disabled.
ODBC auto-detection... ()
ODBC disabled.
iODBC auto-detection... ()
iODBC disabled.
PostgreSQL auto-detection... ()
PostgreSQL disabled.
SQLite2 auto-detection... ()
SQLite2 disabled.
unknown SQL driver: sqlite_symbian
unknown SQL driver: symsql
TDS auto-detection... ()
TDS disabled.
NIS auto-detection... ()
NIS disabled.
Cups auto-detection... ()
Cups disabled.
D-Bus auto-detection... ()
D-Bus disabled.
Glib auto-detection... ()
Glib disabled.
ICU auto-detection... ()
ICU disabled.
PulseAudio auto-detection... ()
PulseAudio disabled.
OpenGL ES 2.x auto-detection... ()
OpenGL ES 2.x disabled.
The OpenGL ES 2.0 functionality test failed!
You might need to modify the include and library search paths by editing
QMAKE_INCDIR_OPENGL_ES2, QMAKE_LIBDIR_OPENGL_ES2 and QMAKE_LIBS_OPENGL_ES2 in
/home/parallels/work31017/qt-everywhere-opensource-src-4.8.5/mkspecs/qws/linux-arm-gnueabi-g++.
I hope That someone could help to solve these problem.Thank you!
This is my qmake.conf.
Hello Han Shan,
There is some information on how to setup an IDE like Qt creator on the following document:
https://community.nxp.com/docs/DOC-328543
However, for further troubleshooting compiling for Qt I would recommend looking into Qt forums where more people is likely to have the expertise to help. You may find them on the link below:
I hope this helps!
Dear,
Thank u very much for your reply .
