These days I am building qt4.8.5 for imx6q,and had some questions.
My BSP is Linux-3.10.17,and the type of hardware is imx6q-rom3420,and i am using yocto project.
When I build qt4.8.5,always failed.
The log is :
Creating qmake. Please wait...
make: Nothing to be done for `first'.
You have not explicitly asked to use pkg-config and are cross-compiling.
pkg-config will not be used to automatically query cflag/lib parameters for
dependencies
floatmath auto-detection... ()
/home/parallels/work31017/qt-everywhere-opensource-src-4.8.5/bin/qmake: 1: /home/parallels/work31017/qt-everywhere-opensource-src-4.8.5/bin/qmake: Syntax error: word unexpected (expecting ")")
make: *** No targets specified and no makefile found. Stop.
floatmath disabled.
mmx auto-detection... ()
mmx disabled.
3dnow auto-detection... ()
3dnow disabled.
sse auto-detection... ()
sse disabled.
sse2 auto-detection... ()
sse2 disabled.
sse3 auto-detection... ()
sse3 disabled.
ssse3 auto-detection... ()
ssse3 disabled.
sse4_1 auto-detection... ()
sse4_1 disabled.
sse4_2 auto-detection... ()
sse4_2 disabled.
avx auto-detection... ()
avx disabled.
neon auto-detection... ()
neon disabled.
ipc_sysv auto-detection... ()
ipc_sysv disabled.
ipc_posix auto-detection... ()
ipc_posix disabled.
libtiff auto-detection... ()
libtiff disabled.
libmng auto-detection... ()
libmng disabled.
DB2 auto-detection... ()
DB2 disabled.
InterBase auto-detection... ()
InterBase disabled.
MySQL (thread-safe) auto-detection... ()
MySQL (thread-safe) disabled.
MySQL (thread-unsafe) auto-detection... ()
MySQL (thread-unsafe) disabled.
OCI auto-detection... ()
OCI disabled.
ODBC auto-detection... ()
ODBC disabled.
iODBC auto-detection... ()
iODBC disabled.
PostgreSQL auto-detection... ()
PostgreSQL disabled.
SQLite2 auto-detection... ()
SQLite2 disabled.
unknown SQL driver: sqlite_symbian
unknown SQL driver: symsql
TDS auto-detection... ()
TDS disabled.
NIS auto-detection... ()
NIS disabled.
Cups auto-detection... ()
Cups disabled.
D-Bus auto-detection... ()
D-Bus disabled.
Glib auto-detection... ()
Glib disabled.
ICU auto-detection... ()
ICU disabled.
PulseAudio auto-detection... ()
PulseAudio disabled.
OpenGL ES 2.x auto-detection... ()
OpenGL ES 2.x disabled.
The OpenGL ES 2.0 functionality test failed!
You might need to modify the include and library search paths by editing
QMAKE_INCDIR_OPENGL_ES2, QMAKE_LIBDIR_OPENGL_ES2 and QMAKE_LIBS_OPENGL_ES2 in
/home/parallels/work31017/qt-everywhere-opensource-src-4.8.5/mkspecs/qws/linux-arm-gnueabi-g++.
I hope That someone could help to solve these problem.Thank you!
Hello Han Shan,
There is some information on how to setup an IDE like Qt creator on the following document:
https://community.nxp.com/docs/DOC-328543
However, for further troubleshooting compiling for Qt I would recommend looking into Qt forums where more people is likely to have the expertise to help. You may find them on the link below:
I hope this helps!
