Some Issues about DDR on MX6DL
797 次查看
tony_l_cai
Dear All,
     In U-boot 2014.04, we find the DDR cfg has a macro CONFIG_USE_PLUGIN, but I dont know how to use it. could you give me more info ?
     and I also want to know how to user ROM controller ,could you give some examples? The content about the MX6DL reference manual is so obscure that I cannot comprehend it.
3Q~
标签 (3)
677 次查看
Hi tony
plugin is described in sect.8.7 Plugin Image
i.MX6SDL Reference Manual (rev.2  5/2015)
http://cache.freescale.com/files/32bit/doc/ref_manual/IMX6SDLRM.pdf
One can consider it as addition to dcd header, as after plugin execution
boot flow returns to ROM. Plugin has not restrictions as dcd header has:
dcd max size 1768 bytes and restricted number accessed peripherals. Also one can
use conditional branch execution.
For boot examples one can look at attached Linux Guide sect.4.5 How to boot the i.MX boards.
