Solo emulation in 8MMINILPD4-EVK
Search instead for
ko-hey
Senior Contributor II
Hi all,
How can I do solo emulation in 8MMINILPD4-EVK?
I wan to estimate single core CPU performance with 8MMINILPD4-EVK so I tried maxcpus parameter which is described in Linux Release Notes but it can't be limited the CPU numbers.
Here are my steps.
$ setenv kernelargs maxcpus=1
$ saveenv
$ boot
On the other hand, I tried disable/enable cores at kernel runtime referring following link and it success.
https://variwiki.com/index.php?title=CPU_freq_and_num_of_cores
Q1.
Could you tell me why the maxcpus parameter doesn't work ?
Q2.
Can we get same result of estimation with disabling at kernel runtime ?
Ko-hey
joanxie
I think you should add this after mmcargs, like
"$setenv mmcargs 'setenv bootargs console=${console},${baudrate} earlycon=${earlycon},${baudrate} root=${mmcroot} maxcpus=1'
$ saveenv"
yes you can disable this in the kernel too
joanxie
$ saveenv"
