Software upgrade in android using recovery mode.
1,385件の閲覧回数
nit123
I am trying to do the software upgrade in android using following update script.
ui_print("extract kernel image...");
package_extract_file("files/uImage", "/tmp/uImage");
# Write uImage to 1M position.
ui_print("writting kernel image");
simple_dd("/tmp/uImage", "/dev/block/mmcblk0", 1048576);
ui_print("extract uramdisk image...");
package_extract_file("files/uramdisk.img", "/tmp/uramdisk.img");
ui_print("writting uramdisk image");
simple_dd("/tmp/uramdisk", "/dev/block/mmcblk0", 6291456);
show_progress(0.1, 5);
I tried other update scripts also.
But this above script i got from imx manual 10.3.2 but not getting why they are using simple_dd.
I tried dd but it fails in recovery mode of android,tried different different options for make it work but no luck.
Please suggest how it works in imx,if anybody have worked.
タグ(1)
0 返答(返信)
