Hello NXP's member,
Do you have any software package of NT3H1101 that implements NFC Host-based Card Emulation for Android 6.0.1-2.1.0 BSP?
Or documents describe how to enable Android 6.0.1 HCE support and adapt to other NTAG solution.
Platform: i.MX6Q custom board
NFC Interface: I2C
BSP: android_M6.0.1_2.1.0
Thanks in advance.
Oliver
Hello Oliver,
Our android BSP for I.MX6 series SoC doesn't support NFC by default, If you need to use them, you refer to the link:
http://www.nxp.com/documents/application_note/AN11597.pdf ( NTAG I²C demo application for Android )
Other documents are here :
Weidong
Hi Wigros,
Thanks for your feedback, seems the documents of NT3H1101/1201 you provided are not implemented on Android side.
Whether the Android only implements NFC controller for full NFC function,no NTAG and HCE only?
BTW, may I have the software package of NXP's PN7xx/PN5xx for Android 6, is it opened?
As I know, lots of mobile devices have NXP's NFC solution inside!
Oliver
