Signal strength (asu) is poor on JB4.2.2 (i.MX6)
Search instead for
lqw39
We are debugging CDMA2000/WCDMA module, and found the signal strength (indicator on status bar) is very weak on JB4.2.2, and we got the incredible result:
1. when dbm is -75, asu is 1;
2. when dbm is -105, asu is 16;
I'm sure the dbm is precise, so the asu should be incorrect.
However, the signal is OK on ICS4.0.4.
Has anybody any idea?
Labels (3)
Tags (3)
jamesbone
It seems this is a problem of Huawei Driver, can you please contact them?.  I believe that  RIL interface would having some problems.
