Hi all
Does someone have experience for connecting Sli1127A and i.MX7D CSI ?
I am trying to interface Sil1127A hdmi chip with IMX7 processor
So I want to confirm the signal connections.
Here is a connection what I think. Does it correct ?
DE ⇔
HSYNC ⇔ CSI_HSYNC
VSYNC ⇔ CSI_VSYNC
ODCK ⇔ CSI_PIXCLK
Q ⇔ CSI_DATAxx
I also refer to the following thread and DE signal don't need to connect.
https://community.nxp.com/message/881323
Here is a datasheet for Sil1127A.
add info:
I'll not use audio data in my system.
BR,
Kohei Tanaka
Solved! Go to Solution.
Hi Kohei
connections seem as correct, you are right DE signal is not needed.
Hi Kohei
