Settings of MMDC MDSCR with programming aid
1,485 次查看
ko-hey
Senior Contributor II
Hi all
I have a question about following programming aid.
https://community.freescale.com/docs/DOC-105967
In line 183 and 184 of the programming aid, it can set a outout drive strength.
However, there are no discription about it in the reference manual.
Where can user find the description in the reference manual ?
ko-hey
1,284 次查看
Yuri
  The mentioned settings relate to configuring drive strength of
an external DRAM part, therefore please use DRAM datasheet
for more details about Mode Registers.
Yuri
1,284 次查看
ko-hey
Hi Yuri
Thank you for your quick response.
I got it.
Ko-hey
