Hi ,
I am trying to setup imx6qsabresd evaluation board as a USB webcam gadget. i have enabled required USB gadget support device driver
I am using "fsl-image-validation-imx" yocto recipe to build sdcard images.
Modules loaded :
modprobe libcomposite
modprobe configfs
modprobe usb_f_uvc
modprobe g_webcam
Below is the output after loading above modules :
g_webcam gadget: uvc_function_bind
g_webcam gadget: Webcam Video Gadget
g_webcam gadget: g_webcam ready
But device does not get detected in Host (P.C)
Please let me know what might be issue and what else is required to turn the EVK board into device mode.
Ramesh
Hi Igor ,
Thanks for the quick response .
I have referred to the example doc (FSL-UT-USB-010.txt )shared by you and it talks about testing external webcam into a USB host on development system i.e imx6qsabresd whereas i am expecting the sabre board (device) to detect as USB webcam gadget on my P.C (host).
Does the imx6qsabre evk board requires a camera module on it to register as webcam gadget on host (P.C) ?
Thanks Ramesh |
Hi Ramesh
one can check usb gadget examples on
doc\mxc_usb_test\test - imx-test - i.MX Driver Test Application Software
