Hi Sergio,
The solution you found really works. I'm using Ubuntu 64bits. We have to change:
@ARGV = grep { `file $_` =~ m,ASCII C program text, } @ARGV;
to
@ARGV = grep { `file $_` =~ m,ASCII\s+.*text, } @ARGV;
on files:
<ltib>/dist/lfs-5.1/base_libs/base_libs.spec
<ltib>/dist/lfs-5.1/glibc/glibc-2.3.2.spec
<ltib>/dist/lfs-5.1/glibc/glibc.spec
Rogerio
