I need to program the imxvpuenc_h264 Gstreamer plugin in C for use with RTP. Where do I find documentation for options like those I have seen in other posts such as gop-size and bitrate? I know I will almost certainly have to set slice sizes or max NAL sizes somehow.
Hi Mike
imxvpuenc_h264 is part gstreamer-imx plugins developed and supported
by community, it may be posted on meta-fsl-arm mailing list, so that someone familiar
with it could try to assist you.
https://lists.yoctoproject.org/listinfo/meta-freescale
difference between community gstreamer-imx plugins and nxp gstreamer plugins described on
trac.gateworks.com/wiki/Yocto/gstreamer
