Dear Sir
Let me check about the setting of Thermal sensor.
It seems that there are four sensor settings in i.MX6.
・CONFIG_THERMAL
・CONFIG_CPU_THERMAL
・CONFIG_IMX_THERMAL
・CONFIG_DEVICE_THERMAL
Q1.
When CONFIG_THERMAL is turned off with MenuConfig, will the other three be OFF?
Eishi SHIBUSAWA
解決済! 解決策の投稿を見る。
Yes, when the CONFIG_THERMAL is Off, all others should go Off as well.
