Setting MAC address on imxull board
1,939 次查看
Et_MM
I am working with a custom board based on the i.MX 6ULL EVK, and I need to permanently set the MAC address for Ethernet to fe:51:11:6c:62:e8. How can I do this using the OTP fuses / burn fuses?"
3 回复数
1,876 次查看
Et_MM
Thanks for the solution.
1,882 次查看
Harvey021
Please refer the attachment for reference to fuse and the section <37.5 OCOTP Memory Map/Register Definition > of IMX6ULLRM
Harvey
1,253 次查看
JesnaK
Thanks for the solution. I will try this.
