Set two sound cards to the same SAI (Linux 4.9 iMX6UL)
3,609 次查看
stefanozuincast
Hi everyone,
I'm trying to update from Linux 4.1 (Yocto Krogoth) to 4.9 (Yocto Sumo) using a iMX6UL. Everything is working fine but I'm not able to use a DAC and ADC both connected to SAI1. In Linux 4.1 there was no problem. Unfortunately in 4.9 a got this message "Trying to bind component to card X but is already bound to card Y", just DAC card is declared after that and works fine using GStreamer or ALSA. Then, I patched soc-core.c to avoid launch this error and both cards finally appear in the list of declared sound cards. But now, when I try to play a sine using GStreamer, I get message "Setting pipeline to PAUSED ..." and cannot kill the process...
I was wondering if with the current kernel drivers is possible to define more than one sound card for the same sai.
标签 (3)
3,238 次查看
stefanozuincast
I've solved by defining a sound card with 2 codecs:
    sound-10 {
        compatible = "simple-audio-card";
        simple-audio-card,name = "10_audio";
        system-clock-direction = "out";
        system-clock-type = "mclk";
        simple-audio-card,dai-link@0{
            format = "i2s";
            cpu {
                sound-dai = <&sai1>;
                dai-tdm-slot-num = <2>;
                system-clock-frequency = <12288000>;
            codec {
                sound-dai = <&codec1>;
                system-clock-id = <2>;
        simple-audio-card,dai-link@1{
            format = "i2s";
            cpu {
            codec {
                sound-dai = <&codec2>;
Is not necessary to patch soc-core file.
4 回复数
923 次查看
surya45
Hi @stefanozuincast ,
i want btsco codec and wm8960  codec drivers to use sai2 interface.
i tried adding the dts nodes as you mentioned. its building fine and android booted up but no codec soundcards  were created.
mentioning the node :
sound-new {
simple-audio-card,name = "mixcard";
simple-audio-card,format = "i2s";
simple-audio-card,bitclock-master = <&dailink_master>;
simple-audio-card,frame-master = <&dailink_master>;
simple-audio-card,mclk-fs = <32>;
simple-audio-card,widgets =
"Microphone", "Mic Jack",
"Line", "Line In",
"Line", "Line Out",
"Speaker", "Speaker",
"Headphone", "Headphone Jack";
simple-audio-card,routing =
"Headphone Jack", "HP_L",
"Headphone Jack", "HP_R",
"Speaker", "SPK_LP",
"Speaker", "SPK_LN",
"LINPUT1", "Mic Jack",
"LINPUT3", "Mic Jack",
"RINPUT1", "Mic Jack",
"RINPUT2", "Mic Jack";
status = "okay";
dailink_master: simple-audio-card,cpu {
sound-dai = <&sai2>;
simple-audio-card,codec {
sound-dai = <&codec>;
simple-audio-card,bitclock-inversion;
simple-audio-card,frame-master = <&btcpu>;
simple-audio-card,bitclock-master = <&btcpu>;
btcpu: simple-audio-card,cpu {
dai-tdm-slot-width = <16>;
sound-dai = <&bt_sco_codec 0>;
please help here @igorpadykov
3,239 次查看
stefanozuincast
    sound-10 {
            format = "i2s";
            cpu {
            codec {
            format = "i2s";
            cpu {
            codec {
3,238 次查看
igorpadykov
Hi Stefano
one can try with nxp linux releases: L4.9.88 (rocko)
https://source.codeaurora.org/external/imx/linux-imx/tree/?h=imx_4.9.88_2.0.0_ga
or L4.14.78 (sumo)
https://source.codeaurora.org/external/imx/linux-imx/tree/?h=imx_4.14.78_1.0.0_ga
3,238 次查看
stefanozuincast
Hi igorpadykov,
I'm currently using Linux Kernel 4.9.88 and I get that error...
This is my audio codecs declaration:
    sound-dac {
        simple-audio-card,name = "pcm179x-audio";
        dailink_master: simple-audio-card,codec {
    sound-adc {
        simple-audio-card,name = "pcm186x-audio";
&i2c4 {
    clock_frequency = <400000>;
    pinctrl-names = "default";
    pinctrl-0 = <&pinctrl_i2c4>;
    status = "okay";
    codec1: pcm1796@4c {
            #sound-dai-cells = <0>;
        compatible = "ti,pcm179x";
        reg = <0x4c>;
        clocks = <&clks IMX6UL_CLK_SAI1>;
        clock-names = "mclk";
    codec2: pcm1864@4a {
        reg = <0x4a>;
        compatible = "ti,pcm1862";
/*Audio CODEC*/
&sai2 {
    pinctrl-0 = <&pinctrl_sai2>;
    assigned-clocks = <&clks IMX6UL_CLK_SAI2_SEL>,<&clks IMX6UL_CLK_SAI2>;
    assigned-clock-parents = <&clks IMX6UL_CLK_PLL4_AUDIO_DIV>;
    assigned-clock-rates = <0>, <12288000>;
    fsl,sai-mclk-direction-output;
    status = "okay";
/*Audio DAC & ADC*/
&sai1 {
    #sound-dai-cells= <1>;
    pinctrl-0 = <&pinctrl_sai1>;
    assigned-clocks = <&clks IMX6UL_CLK_SAI1_SEL>,<&clks IMX6UL_CLK_SAI1>;
    status = "okay";
