Set Input pin to PULL-UP
2,234 次查看
Chayma
Hello, I am working on IMX8M mini EVK. I would like to know how to set a GPIO pin to INPUT and PULL-UP. Thank you.
2,228 次查看
Hi Chayma
one can look at documentation
https://source.codeaurora.org/external/imx/linux-imx/tree/Documentation/devicetree/bindings/pinctrl/...
for example MX8MM_IOMUXC_UART1_RXD_UART1_DCE_RX 0x140, value 0x140 is described in
sect.8.2.5.291 Pad Control Register (IOMUXC_SW_PAD_CTL_PAD_UART1_RXD)
i.MX 8M Mini Applications Processor Reference Manual
Direction can be set in uboot.
