Seco version 3.7.1 throws unknown SECO Event[1] = 0x00DAF429
Chandni
Hi Team,
I am wanting to use seco version 3.7.1 for my imx8 chip. However I get below seco events:
SECO Event[0] = 0x0087EE00
0x0087EE00 --> is not a problem as i did not OEM close my board and I am not using a signed image.
However, the other event  I am not sure what is wrong.
For 0x00DAF429:
Status byte: 0x29  is AHAB_FAILURE_IND
Ind byte: 0xF4 is AHAB_INVALID_MESSAGE_IND
0x00DA is not known, i assume it is a command, but its not documented anywhere.
2  questions:
  1. Could you please point me to a direction which could help me fix 0x00DAF429 error? As per your documents my board cannot go to OEM close with this seco event, correct?
  2. Can I downgrade seco firmware version say for example from 3.8.6 to 3.7.1?
Thanks in advance.
@Harvey021
