On a Utilite pro with kernel 3.0.35 and Ubuntu 12.04.3 the following problem appears when using
the system for longer runtime and using more the 60% of the 2 GB RAM.
Utilite & Trim-Slice Users Forum - View topic - Video Artifacts Using Ubuntu
When continuing to use the system when these artifacts appear, most
of the time an axi bus error with screen freeze happens.
The current workaround is to use a modified xorg.conf file
with the accelerated fbdev driver (loosing openGL acceleration), but not the vivante driver.
Has this problem been seen on other i.mx6 based systems/boards with 2 GB RAM ?
Peter Bauer
http://bitkistl.blogspot.com
